  • Similar Content
    • By lordpagano
      Hi everyone! I bought an Aeromatic 1912 A1308 watch (have not received it yet) and I was wondering what caliber does it use. By chance I found the attached pictures, I believe it's the same caliber but I found no information on it, only that it may be a Seagull. Can somebody help?
      Thank you!!
    • By Mark
      Join me as I strip down, service and review this Chinese ETA 2892-A2 clone. Seagull ST1812 watch movement. There was a couple of issues to deal with but altogether a fairly impressive movement for the price.
    • By dferrier
      Here is how one guy did it:
    • By haratua
      I just got a new Chinese movement (TY2867), and when I push the winder in, the movement won't start. I've manually wind it a few times, pull the winder out and push it back in.
      What could be the issue? Thanks
    • By haratua
      I am struggling to find a way to remove the movement on this large Ingersoll watch from its case. Cannot seem to find any screws that pin the movement to the case.
      Tried to remove the steel spacer, it is un-movable even with pliers.
      Does it mean that that I have to come from the glass? If through the glass, do I pry on the small opening on the bezel (see the second picture attached)?
      Appreciate any helps. Thanks.
    • I have a nice big concrete block outside. I feel like taking this POS, putting it on that block  and pounding the shit out of it until its a nice homogeneous, flat piece of metal.
    • What the problem here is for your question is Mark's video is confusing. Normally when you do a balance staff you would statically poise first then sometimes dynamically poise. If your dynamic poising you use eight pendant positions usually. So in his video he comments for this particular watch he is dynamic poising. Then adjusting to positions is an interesting term or as your question is which positions should you worry about timekeeping in? Basically what you're doing by timing the watch on the timing machine in a variety of positions is your verifying the watch does keep time in those positions.  So for pocket watches dial up and crown up are the most common. For wristwatches I'm attaching what Omega recommends for their watches
    • check each as old hippy said but end shakes on a 3rd wheel allow a lot more play than lets say a balance or escape. you can get away with too much end shake and not loose much amplitude, too little will def not work though and will def result in a very low amp and or stop the movement. train wheels being loose is always better than too tight in my opinion
    • its farfo.com dont put the www. or just google farfo vintage watches ridgewood nj. archer is a memeber on teh Watchuseek forums and is very good esp when it comes to high end watches like omega. he is a certified omega repairer, not many of those around. he uses the same equipment they uses at the omega facilities. 100,000s worth of equipment
    • Try winding through the ratchet wheel, put screwdriver in the wheels slot,turn to wind , should wind full.
