Need Advise in Removing Tourbillon Movement (SeaGull maybe)
Welcome to the forum, enjoy.That is watch have not serviced before. Maybe the front bezel unscrews.
Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement. What happened you have already made 7 posts😀
I was just thinking, maybe a better solution for my design would be to have a standard base, and then use insert rings for each movement? This would reduce plastic used and print time as well as storage of the different holders? Something like this:
By rjenkinsgb · Posted
Look carefully at the tube end?? It appears to me to have a fragment thread visible? Either that or a step just away from the end? I can imagine a chamfer, but a step seems odd - but I've never seen the tubes used on these.
