  • Similar Content
    • By lordpagano
      Hi everyone! I bought an Aeromatic 1912 A1308 watch (have not received it yet) and I was wondering what caliber does it use. By chance I found the attached pictures, I believe it's the same caliber but I found no information on it, only that it may be a Seagull. Can somebody help?
      Thank you!!
    • By Mark
      Join me as I strip down, service and review this Chinese ETA 2892-A2 clone. Seagull ST1812 watch movement. There was a couple of issues to deal with but altogether a fairly impressive movement for the price.
    • By dferrier
      Here is how one guy did it:
    • By haratua
      I just got a new Chinese movement (TY2867), and when I push the winder in, the movement won't start. I've manually wind it a few times, pull the winder out and push it back in.
      What could be the issue? Thanks
    • By haratua
      I am struggling to find a way to remove the movement on this large Ingersoll watch from its case. Cannot seem to find any screws that pin the movement to the case.
      Tried to remove the steel spacer, it is un-movable even with pliers.
      Does it mean that that I have to come from the glass? If through the glass, do I pry on the small opening on the bezel (see the second picture attached)?
      Appreciate any helps. Thanks.
    • Just as a curiousity here is the tools recommended by ETA the bearing tool and some others..
    • Thanks all but the price of the Horotec tool is a bit prohibitive... I have managed to free it with a very sharp piece of peg wood in one of the cut outs and push it round..The bearing is OK its just that the balance needs some work and you cant remove it with the rotor in place.
    • To remove the beaing you need a special tool but just to remove the rotor you just take of the three screws holding the automatic mechanism, turn it around and unscrew three small screws on the underside and the rotor gets loose.. Could take a couple of shots for you if you wish..
    • Blimey, I see what you mean. What you've got there would appear to be two French-made Framelac pin-levers, a movement maker about which very little seems to be recorded. I've attached an image from the Uhrforum.de of the jewelled-lever FR 304 for comparison of the bridge configuration (similar) and the shape of the balance cock (identical).
    • Strange. And the setting lever is turned the right way up? Can't see on the picture.
