  • Similar Content
    • By lordpagano
      Hi everyone! I bought an Aeromatic 1912 A1308 watch (have not received it yet) and I was wondering what caliber does it use. By chance I found the attached pictures, I believe it's the same caliber but I found no information on it, only that it may be a Seagull. Can somebody help?
      Thank you!!
    • By Mark
      Join me as I strip down, service and review this Chinese ETA 2892-A2 clone. Seagull ST1812 watch movement. There was a couple of issues to deal with but altogether a fairly impressive movement for the price.
    • By dferrier
      Here is how one guy did it:
    • By haratua
      I just got a new Chinese movement (TY2867), and when I push the winder in, the movement won't start. I've manually wind it a few times, pull the winder out and push it back in.
      What could be the issue? Thanks
    • By haratua
      I am struggling to find a way to remove the movement on this large Ingersoll watch from its case. Cannot seem to find any screws that pin the movement to the case.
      Tried to remove the steel spacer, it is un-movable even with pliers.
      Does it mean that that I have to come from the glass? If through the glass, do I pry on the small opening on the bezel (see the second picture attached)?
      Appreciate any helps. Thanks.
    • Hi all,   I'm new to this fascinating discipline.   I'm a plumbing and heating contractor by trade.   Been in that industry for 35 plus years.   My other interests include gunsmithing.   I stumbled on to one of Marks YouTube videos and I was drawn right in.   I've always been interested in mechanical things.   Thanks for all of the information I've already received.    Hope to pursue this and gain skill and knowledge.
    • Hi JDM, This is super consolidation work. Huge help. Thanks very much.
    • I had the same problem on a pocket watch. Turned out to be a loose impulse jewel. Re-shellaced it and all was good. Sent from my iPhone using Tapatalk Pro
    • Look at the spring position BETWEEN the regulator pins.  If its central to both pins, I vote to leave it alone.  The old guys (Fried and De Carle) often suggested using a slight bend in the hairspring  to centralize the spring position between regulator pins.  It does appear to be a little eccentric.   At any rate, I doubt your slight kink would be a reason for low amplitude.   Good luck, RMD
