Hi from MikeR
MikeR
HI, I'm Mike and live in the south of England, an electrical engineer, semi-retired, worked on antique clock repair for a number of years and now into watches. The only concession I make for electronic watches is Citizen. Excellent engineering. Other than that they must me mechanical.
Hi Mike, Citizen are excellent but so are Pulsar and Seiko. Good Pulsar, then expect around 3-5 Sec`s PA. Problem is that old mechanical watches are getting worn out and spares are very difficult. Very few have been serviced for many years. Anyway, well done and keep it up. I live in Hampshire. Mark Lovick is the watch guru and presents superb repairs and tutorials. I watch him on U Tube regularly. There is little help around here for amateurs so Marks video`s are a real help. Best regards, Mike.
Hi Mike
Thanks for responding, its like a voice from the wilderness when you are new to a site. I mentioned citizen particularly because of the eco light power source and the radio driven time correction which occurs every 24 hours, very clever. However you are not wrong with complements to Seiko and pulsar.
I've just completed Mark's level 1 and level 2 watch repair courses. excellent. Looking forward to level 3. Regards Mike.
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
    • Thanks guys.  quick question. For automatic movement, particularly this one. can I power down the main spring by pushing this rachet down?  i've gotten pretty used to SW210 and powering down a manual movement. But so far i've only been waiting for the auto movement to run out of juice before opening the case.
