Freshly serviced pin pallet movement runs slow
Could you glue two pieces together for rigidity and separate after forming? -
By watchweasol · Posted
Hi. Sounds like a problem clock, can you post some picture# of the clock and the parts in question please. Thank you -
The first broke while i was using a dremel to shape the jumper spring at the join, i guess you call it the fixator, the disk grapped hold and flicked it off . The second time same place but while i was filing. This steel feels more malleable, it is annealed steel. Working out the detent on the jumper is a real. pain in the butt.
