Blow out a saphire crystal?
PeterGe
Hi guys,
I' got a watch here which is clearly a front loader. The back screws off but the movement ring is machined into the case itself. Also the opening of the caseback is to small to fit the dial through.
There also isn't any seam or gap in the case to remove the bezel,  besides the back lid, it is a solid case.
In this situation I usually use a pump to blow the crystal out after removing the stem. However, until now all the front loaders I've dealt with had acrylic crystal. This one however has a sapphire crystal.
My only concern is that the crystal could break under the pressure.
pictures attached.
Did anyone came across something similar?
CCS390A-RS5-0013-Automatic-Back-PX-Edit-Download_4bc5ad91-14c0-4663-8adb-b3eef1725a37.jpg
quick update.
The lift tool can't be used, there is nothing to grab onto.
Blowing out the crystal didn't work so for. I can't set enough pressure.
Granted, I don't have a fancy Bergeon pump, I use a syringe. I'll try using the compressor, as i have already done in the past, but I have lost my adaptor.
I also contacted the manufacturer. They don't have an idea as they don't service their watches themselves. :rolleyes:
I might get a figurative slap to the head for saying this, as its not ideal procedure, but a can of compressed air, like which is used for cleaning computers, is often effective. (they can sometimes spit butane though, which if it did would not be ideal for the movement, but likely not disastrous either)
Another update.
After buying a new adapter/connector for my compressor (lost the old one), i tried blowing out the crystal this way.
As always I increased the pressure gradually, but even after putting significant pressure on it, the crystal remained in place.
I'm worried putting more pressure is gonna break things.
I've put this one on hold for the moment & have made an inquiry with the official service center. Let's see what they have to say about this.
To be continued........
As explained in my previous post, the compressor didn't even do the trick. So the can of compressed air won't do the trick either. Might work for acryl crystals though.
Can you post a picture with the back removed. I would like to see how the mov.t attaches to the dial, and if there is enough support to press it down so eventually the crystal is pushed out. However, that is not something I would recommend to do, I'd try first an higher pressure compressor with a better seal to the pendant tube.
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
