Blow out a saphire crystal?
PeterGe
Hi guys,
I' got a watch here which is clearly a front loader. The back screws off but the movement ring is machined into the case itself. Also the opening of the caseback is to small to fit the dial through.
There also isn't any seam or gap in the case to remove the bezel,  besides the back lid, it is a solid case.
In this situation I usually use a pump to blow the crystal out after removing the stem. However, until now all the front loaders I've dealt with had acrylic crystal. This one however has a sapphire crystal.
My only concern is that the crystal could break under the pressure.
pictures attached.
Did anyone came across something similar?
CCS390A-RS5-0013-Automatic-Back-PX-Edit-Download_4bc5ad91-14c0-4663-8adb-b3eef1725a37.jpg
quick update.
The lift tool can't be used, there is nothing to grab onto.
Blowing out the crystal didn't work so for. I can't set enough pressure.
Granted, I don't have a fancy Bergeon pump, I use a syringe. I'll try using the compressor, as i have already done in the past, but I have lost my adaptor.
I also contacted the manufacturer. They don't have an idea as they don't service their watches themselves. :rolleyes:
I might get a figurative slap to the head for saying this, as its not ideal procedure, but a can of compressed air, like which is used for cleaning computers, is often effective. (they can sometimes spit butane though, which if it did would not be ideal for the movement, but likely not disastrous either)
Another update.
After buying a new adapter/connector for my compressor (lost the old one), i tried blowing out the crystal this way.
As always I increased the pressure gradually, but even after putting significant pressure on it, the crystal remained in place.
I'm worried putting more pressure is gonna break things.
I've put this one on hold for the moment & have made an inquiry with the official service center. Let's see what they have to say about this.
To be continued........
As explained in my previous post, the compressor didn't even do the trick. So the can of compressed air won't do the trick either. Might work for acryl crystals though.
Can you post a picture with the back removed. I would like to see how the mov.t attaches to the dial, and if there is enough support to press it down so eventually the crystal is pushed out. However, that is not something I would recommend to do, I'd try first an higher pressure compressor with a better seal to the pendant tube.
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
