Hi from Singapore!
trident
52 minutes ago, trident said:
Hi,
I am from Sinagpore. Was into watch collecting but took up a watch repair course a few months ago. Have been practicing with some old watches. And I hope to learn from all the experts here.
Welcome onboard! The more u practices the better u will be.
Hi friend, My Grandson  collects watches. I learnt a little many years ago from a swiss trained watchmaker and have recently taken it up again to pass the time with interest. I have had one failure which I am now getting on top of as it had been botched up years ago by a cowboy who got it going to sell it !.  Interesting !!. The more we practice the better we get. Amateurs are not liked a lot over here very much by the watch making fraternity but there are not many "pro`s" left now. I had a Chinese watch here last week for a new crystal. Clone ETA. Very good it was as well. Good wishes and best regards,  Mike. PS. Have you got a copy of Practical Watch Repairing ? I use it often for reference and Mark Lovick on U Tube who runs courses is an excellent watch repairer.  I am bit old for his courses almost 76 now. I also have purchased a Timegrapher 1900 (£147) GBPS. and worth every penny. Good wishes, Mike.
Thanks Mike for the warm Welcome. And yes I do hv a copy of Practical Watch Repairing and a timegrapher too. I have just cleaned and oiled a Russian Slava 2428. The date wheel mechanism is a bit tricky though.  Hoping to complete it today or tmr.
On 11/13/2017 at 4:04 AM, trident said:
Hi,
Well done trident, you are doing OK.  Good luck with the Slava 2428. You will fix it just take your time. I  cleaned an old friends  manual wind Avia yesterday,  Then a tiny touch of oil on pivots etc.  The balance is worn but it keeps reasonable time now. He is very pleased and one can easily make a rod for ones back trying to get an old watch perfect on the Timegrapher. If these old wrist watches keep reasonable time dial up and crown facing down then I am satisfied. Mark Lovick would do better but I will never have his skill, he is excellent at this business. The best that I have ever seen. Good wishes friend.  PS. I do not use specialist cleaning fluids. Just Benzene and usually Naphtha with a U/S cleaner,  for oil I use Pegasus or Anchor. I find these materials to be fine. Best regards, Mike.
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
