Adjusting Nut for Boley Leinen Lathe
jdrichard
I set up my new Boley Leinen Reform lathe but the adjusting nut for the spindle does not lock as it is not a split nut and has no way of locking. I have included the photos. Would you know where one could get ine of these nuts?
2d688f96903d37721e564044e5b38326.jpg763f0dffeda9da145a01ab4c0f62b28b.jpg6ca0f712d7cc22edc4f99d7cedc6af91.jpg5b6509b7f0290f837f664e2d6003297b.jpg57cd5d7cf5a4bbd594d4126c8ddd8b2f.jpgc7c701465476c789622de155105fe662.jpg9d5f015928eb085dff4bcb9fafc23299.jpg
Sent from Yahoo Mail for iPhone
I'd try to find out what is factory and replicate that, I'll look at mine but I don't want to take it apart.  I have enough machines in pieces strewn across my basement and garage lol.
Making a nut like that is very easy for anyone with a machine shop, just make a drawing and get it made.....but first I'd want to know what about it isn't factory, and if it is factory, why it isn't working
Edited by measuretwice
I agree. It is so hard to find and data on boley leinen reform lathes and what the nut is supposed to be. Probably need a hand from all the resources out there. I have worn out the Google keys on my tablet.
Sent from my GT-N5110 using Tapatalk
JD, you require two thin nuts, one adjusts the end play of the shaft and the other is tightened against the adjuster nut to lock it.  You will require two "C" spanners to me the adjustment.
The nuts should look like these :-
Edited by Geo
Why not split the one you have and compress it slightly if you want to go that way?
I was going to get a nut that matches the one i have and do just that. There is a great fastener store 10 min from my house. Got all the hardware to bolt the lathe and motor to my deske04bf195d510f9612866e2fb82ac56bf.jpg
On close inspection, it looks like the brass cover and the nut have been made as replacements.  The cover, appears to have been split with a hacksaw given that there are what appears to be linear scratching in the slot, and the depth (too shallow) and finish of the the threads do not look right for a machine made by Boley.
    • Snap! I recently finished my Gruen 510 movement - though the case for mine is in a rather sad state; I'm going to try re-plating it (in nickel, it's not a gold one).   Re. the screws, I got a few of the one gram mixed batches from ebay. I've only needed a couple of screws for things so far, both rare, minuscule types - but both in the mix, after enough time sorting through them! The ones such as normal bridge screws are quite common in those lots.
