British military 1917 evaluation wristwatch
wls1971
This popped up on ebay last week as a £50.00 buy it now
During the Great war the British military had been issuing pocket watches to serving personnel and hadn't supplied wristwatches, these where instead bought mainly by officers privately for use at the front lines with wristwatches improving and the introduction of the water resistant cases, unbreakable crystals and radium dials the Trench watch was born and became an item of necessity for serving personnel.
It wasn't until 1917 that the war department purchased the first batches of wristwatches supplied in two forms the first being a classic trench watch of water resistant case, black dial with radium numerals and unbreakable crystal and the second type being a large cased snap back, black dial with radium numerals all had 15 jewel Swiss movements. These watches where purchased for the purpose of evaluation to assess the usefulness of issuing wristwatches to serving personnel.
This watch is of the snap back type and has a unusually large for the period 38mm  case made of nickle, the dial is  black enamel with radium numerals.
All the snap back models have issue numbers that follow the same form a five digit number beginning with a nine followed by a letter M there is also a Broad arrow mark or Pheon crudely stamped on to the back some watches are stamped with two broad arrow marks that touch at the tip this is thought to indicate that the watch had been withdraw from service.
The movement in these large snap back models is the same in all known watches where as in the water resistant 1917 watches there is some variation. The movement is a good quality 15 jewel movement and no one has yet been able to identify who manufactured them there are no identifying marks but there is a brevet patent number on the dial side so it may be possible to trace that and establish who made the movements.
No one is sure what branch of the armed forces these snap back watches where issued to but it cant have been to front line personnel because having no water resistance would have rendered them pretty useless in the field, many have speculated that they could have been issued to the flying corps because the design mirrors quite closely the pocket watches already issued to them at the time, these snap back models where only issued in 1917 and withdraw from service shortly after, but the water resistant watch became a regular issue watch there after IMG_2628.thumb.JPG.351ef07a95fe2f8794a765e1b85db90d.JPG
It is however an interesting footnote in the development of the military wristwatch and is amongst the  first officially issued and stamped British military watches of the Great War.
Edited by wls1971
25 minutes ago, Geo said:
Wis, I think it may be an Electa movement
 I will have to search through my movement catalogues and see if I can get a dial side match on the setting lever bridge I've already tried Bestfit and found no match I shall try and look for a dial side photo of some Gallet Electra movements that will tell me for sure as there are some similarities on the bridges.
  • 3 years later...
Have you got the patent number, I can look it up?
Thanks. Carl.
Also, the watch below has what I am sure is a smaller version of the same movement:
This movement is a Fontainemelon but I would have thought if the mystery movement was one it might have been identified. There are so many similarities though I would go with Fontainemelon if I had to choose.
I've done a comparison. If you ignore the bridges and plates and look at the screw, pivot and wheel placement from the FHF to the left and then compare to the finish of the wheels and the movement of the FHF to the right it looks like a match to me.
A picture of the dial side would clinch it.
Edited by Penfold
    • An incabloc spring? About 10p at the current price 🤣
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
