British military 1917 evaluation wristwatch
wls1971
This popped up on ebay last week as a £50.00 buy it now
During the Great war the British military had been issuing pocket watches to serving personnel and hadn't supplied wristwatches, these where instead bought mainly by officers privately for use at the front lines with wristwatches improving and the introduction of the water resistant cases, unbreakable crystals and radium dials the Trench watch was born and became an item of necessity for serving personnel.
It wasn't until 1917 that the war department purchased the first batches of wristwatches supplied in two forms the first being a classic trench watch of water resistant case, black dial with radium numerals and unbreakable crystal and the second type being a large cased snap back, black dial with radium numerals all had 15 jewel Swiss movements. These watches where purchased for the purpose of evaluation to assess the usefulness of issuing wristwatches to serving personnel.
This watch is of the snap back type and has a unusually large for the period 38mm  case made of nickle, the dial is  black enamel with radium numerals.
All the snap back models have issue numbers that follow the same form a five digit number beginning with a nine followed by a letter M there is also a Broad arrow mark or Pheon crudely stamped on to the back some watches are stamped with two broad arrow marks that touch at the tip this is thought to indicate that the watch had been withdraw from service.
The movement in these large snap back models is the same in all known watches where as in the water resistant 1917 watches there is some variation. The movement is a good quality 15 jewel movement and no one has yet been able to identify who manufactured them there are no identifying marks but there is a brevet patent number on the dial side so it may be possible to trace that and establish who made the movements.
No one is sure what branch of the armed forces these snap back watches where issued to but it cant have been to front line personnel because having no water resistance would have rendered them pretty useless in the field, many have speculated that they could have been issued to the flying corps because the design mirrors quite closely the pocket watches already issued to them at the time, these snap back models where only issued in 1917 and withdraw from service shortly after, but the water resistant watch became a regular issue watch there after IMG_2628.thumb.JPG.351ef07a95fe2f8794a765e1b85db90d.JPG
It is however an interesting footnote in the development of the military wristwatch and is amongst the  first officially issued and stamped British military watches of the Great War.
Edited by wls1971
25 minutes ago, Geo said:
Wis, I think it may be an Electa movement
 I will have to search through my movement catalogues and see if I can get a dial side match on the setting lever bridge I've already tried Bestfit and found no match I shall try and look for a dial side photo of some Gallet Electra movements that will tell me for sure as there are some similarities on the bridges.
  • 3 years later...
Have you got the patent number, I can look it up?
Thanks. Carl.
Also, the watch below has what I am sure is a smaller version of the same movement:
This movement is a Fontainemelon but I would have thought if the mystery movement was one it might have been identified. There are so many similarities though I would go with Fontainemelon if I had to choose.
I've done a comparison. If you ignore the bridges and plates and look at the screw, pivot and wheel placement from the FHF to the left and then compare to the finish of the wheels and the movement of the FHF to the right it looks like a match to me.
A picture of the dial side would clinch it.
Edited by Penfold
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
