taking apart a Seiko 5Y23
If you have hand levers (as in two separate levers not the modern presto type tool) you can remove this in a similar manner to hands, to pry it directly up, you may be able to improvise with screwdrivers otherwise, but that's the method, first time i saw this I thought it had to be pulled apart somehow like other C-clips but no, it pries up and off and is then pressed directly back down again to be refitted.
  • Thanks 2
16 hours ago, measuretwice said:
It seems to me the brass in the centre has to come off - any suggestions on how to do so without making a mess of things?
Just don't buff the "brass" off, that would make a sure mess. :D
progress report......
You know what the difference is between a watchmaker who knows what he's doing and me?  sore knees searching the tiled floor for parts.  An that's with a bench with glass sides back and top and the pull out catch tray.  Good news is I'm getting lots of practice and manual dexterity is improving.  I usually find the part, but this time I managed to lose the rotor when it flew off :(.  Being magnetic exacerbates the challenge, it could have stuck to so many things.
This movement is out of production.  I suppose these electronic watches are sort of a disposable consumer thing given the electronics will eventually fail, and with all the plastic they're not exactly inspiring....but hey, that one lonely jewel needed to be serviced and I'm a dog with a bone.
As it turns out the yoke is just about rusted through.  While Seiko forsakes you on the movement, the good news is both parts are still used in other watches (yoke and lost rotor) so they're available and on order.  Hopefully I can make it work.
The symptom of the watch was a jumpy second hand and not really keeping time.  Turns out there were bits of metal stuck to the rotor, no doubt the missing chunks of the yoke.  Interesting how the metal corroded in just that one spot which is an obvious stress riser.  Stress does increase corrosion in steel so it seems a bit of a design flaw....the thin spring arm could have been wider through this section.   Other than some crud from the battery, there was no other corrosion in the watch
Edited by measuretwice
  • 1 year later...
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
    • Welcome from a fellow Seiko enthusiast, there are lots of us on this forum.
    • Nickelsilver is right, movement diameter and keyless works ‘fingerprint’ are important for identifying movements. That said, this appears to be a 7 jewel version of the a Revue 30 movement.  A quick search with google turns up parts movements, and individual parts should be quite easy to come by.  Hope that helps, Mark
