Hello from Alabama
fireftr45
Hello All, My name is Erik, a Swedish-American New Jersey native, living in coastal Alabama which is right next to Pensacola, Florida.  I am a recently retired firefighter and former US Navy Submariner.  I have been interested in watches all my life and got more serious about them nearly 10 years ago.  Mostly diver watches and pilot watches but I am starting to gain an interest and appreciation for all of them.  I have been "Modding" Seiko watches for about 5 or so years and want to go deeper into the movements and repair.
I just completed level 1 & 2 of the watch classes and am now starting to practice stripping a movement.  I am ordering a seagull unitas clone, but it won't be here till almost Christmas so I have begun to strip an old 7S26 Seiko movement down.  While Modding, I pushed to hard while putting the hands on and something popped.  In my tear down I discovered that the cannon pinion had popped free which accounts for the minute hand free spinning.
I am taking the advice (from the classes) seriously and just trying to just gain some experience with the tweezers and screwdrivers.  While taking apart the 7S26 I could see I'd need a lot of practice.  If you guys could've seen how badly I handled the balance complete, you'd be laughing!!  I managed not to have bent anything I hope, but Mark makes it look easy in the videos.  I did manage to get it reinstalled on the empty main plate while all of these parts await cleaning.
Ultimately, my goal is to restore 2 watches.  My Godfather's Welsbro Chronograph (1950's) with a Valjoux 7733, and my Grandfather's Record Geneve Curvex (1944).  I am placing no time limit on these goals as I am sure it will be some time till I have the confidence to touch them.  After that, I would like to restore old Seiko and Swiss watches and other projects I might like.
Looking forward to having some fun here and making some new friends!
Hi Erik, All good stuff old boy. You have done well with Marks courses. He is as good as it gets. I was going for it but don`t really have the time. I am nearly 76 now  and am just an amateur repairer.  I was in electronic design MSc. Electronics and Just A level physics. I got into watches about 1962 as a hobby and started again 2 years ago. I have fixed many and only had one disaster, an  Omega Seamaster 300 which I should get on top of one day. It is my Grandsons and the balance is very worn and to boot I lost the top balance jewel under the incabloc lyre. Omega will sell you nothing. I may put an ETA  or similar movt: in it if one will fit Joe will not know the difference and it will keep good time. The Omega 552 can go in the drawer. Well, good wishes to you and keep em ticking !!.
6
Hello there. This is a great group here and I am too, hope to take Mark's course sometimes.
1 hour ago, vinn3 said:
Thanks for serving - UNDER WATER !  I  was just a "dry dock nuckel buster".  your  gona like it here.  vin
Likewise Vin!  I did 3 trips through the yards while on those boats, 2 fixed drydocks and 1 floater.  It was a neat experience but always ended up being winter in Connecticut.  Thanks again for the welcome!  Looking forward to it.
  • 6 months later...
Hi fireftr45, you are doing very well, keep going and develop a very light touch with mechanical sympathy ! Be especially careful with the balance. Once the Balance is free I lift it out carefully with the tweezers under and over the wheel as the HS does not get stretched by this method. Keep going and all good wishes. Mike.
Edited by ecodec
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
