2836-2 Casing
Hi
I am having a problem casing my 2836-2 movement. The case has a spacer because of the size difference. That part seems OK.
The main problem is the second hand pushed against the crystal when the caseback is tightened.
There are case screws and a ring to put on the movement but, I put it on, it doesn't fit in the spacer ring properly. It's also very hard to fit.
Any suggestions are welcome.
Dave
Are you assembling your own watch from spare part from here and there?
Then the onus is on you to resolve any impinging part and other issue, it may require fabrication and imagination. No ready recipe, sorry.
  • 2 months later...
I was having problems with a casing kit for the 2836-2.
First, it wasn't made clear that placement of part 145, the ring that fits between the dial and movement, was absolutely necessary; it allows the day and date rings to turn freely.
Second, there was a spacer ring to go between the case and the movement supplied with it that didn't fit properly. I used some pieces of small rubber tubing as a spacer instead. I'm thinking that this fix isn't exactly good watchmaking technique but the watch works now and it didn't before, so...
Just thought I'd pass that along for anyone who is looking to case a 2836-2.
This was used by IWC in the sixties as a way of protecting movements from sudden shock I have a Yacht Club that uses 5 rubber blocks as spacers, it was also used by other watch makers so the idea must have some merit.
  • jdm locked and unlocked this topic
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
