How do you dismantle a Horia tool?
matabog
Well logic would dictate that if it was assembled then it should disassemble I think the micrometer part should lift out from the top once the screw is removed or that appears to be what this chap has done with his, pity the site is in Chinese but there are pictures,
http://www.kwanghun.com/3hands/index.php?document_srl=181782&mid=hkhdiary
10 minutes ago, matabog said:
by the way, in google chrome you can right click -> translate to english and voila!
Ahh yes I see now he's converting it to take Seitz pushers which are a different size to Horia, I really am computer illiterate thanks for the tip
I started to blabber on about 99.9% of micrometer barrels are a very careful interference fit into the frame and I wouldn't try to remove it...when the brain says, "I think I have one of those".  Yup, so I took it apart for you.  Take the screw right out, its just a detent holding the barrel in the frame - you can see the dimple it sets in on the barrel.  Put a block of wood underneath business end (anvil in micrometer parlance) and carefully screw the micrometer down into it.  It will push the barrel out of the frame.
The threads are very robust, much more so than a 40 tpi micrometer...after all its designed for pressing.  It came out with minimal force, you won't hurt it :)
apparently mine too needs a good cleaning....I wonder what might dissolve the grime without damaging the crinkle/wrinkle finished (that I wish I could do)
Edited by measuretwice
  • Thanks 2
VHT Crinkle/wrinkle spray paint can be bought used mainly for car restoration, goes on glossy but the careful use of a heat gun produces the crinkle/wrinkle pattern its a great robust finish its a pity its not used more often now a days I have so many things made in the 1940-1950's that have the finish including my lathe.
THANK YOU!
You could try some benzine (Neophaline) to wash the grime.
Once I saw wls1971's post I understood how it went so I tried taking off the screw and pushing the business end into a brass piece but I chickened out. I had turned quite hard on the handle but it hadn't "said" anything
I will let it be for now, I didn't get to use it yet :)I believe it's an older model with that wrinkle finish - I think nowadays it has a glossy finish. But mine doesn't have any grime on it so either hasn't seen much work, which I doubt, or it's been taken good care of very well  - or it's been washed before shipping :))
Good answer above. I did once exchange emails with someone at Horia - I think it might have even been the owner, seems quite a small company for making such a great range of tools. I was asking about this very subject, but unfortunately I must have deleted the correspondence. I'm pretty sure the procedure was the same or similar.
However when I told him that I wanted to buy a 4mm spindle from him so I could use the tool interchangeably with both 3mm and 4mm pushers he told me he wouldn't advise it, that the spindle and/or the tool might be damaged by repeatedly inserting and removing and it should only be done if necessary. Whether he was trying to get me to buy another tool who knows? He did seem quite genuine, and was fine that I didn't buy the extra spindle and pushers I was going to.
I think when you buy a tool like this 2nd hand as a general rule it is highly likely to be in good condition as someone paid a lot of money for it new and will have looked after it. Given the cost of a new one they also probably knew how to use it properly as well ;).
Stephen
I would think there is merit to that.  Achieving that sort of fit is a challenge in machining and tool making, of of the biggest.   I've done it often enough when making fits for high end bearings, you have maybe a micron in each direction then its too tight or too loose (as defined by the bearing manufacturer).  You have to hold your tongue just so when making parts like that.  On that assembly, the tolerance are just so small, any bit of wear will make it too lose, any ding will make it too tight.
Its not going to wear so quickly that you should never take it apart, and its construction is such that you have to disassemble to clean and oil.   otoh I wouldn't do it daily; that precision fit cannot be damaged while its safely assembled.
  • 1 year later...
On Horia's website, horia.ch, you can purchase either a 3 mm or 4 mm spindle {REF. PO 61-02} SPINDLE for a price of CHF 62.90.  https://www.horia.ch/en/Products/Jewellling-Setting-staking-tools/Jewelling-tools/Accessories/Spindle-9.html
So if someone has a Horia tool with the 3 mm spindle, but wants to use 4 mm Seitz pushers (or 4 mm Horia pushers for that matter), you can buy the 4 mm spindle and switch it out.
I would agree with @measuretwice that you don't want to be switching spindles often.  I'd do it once and leave it alone.
  • Similar Content
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
