transporter
Gents I, m currently working on a swiza mantle alarm clock, 8 day movement I believe, anyway, I stripped cleaned and lubed the movement and got the alarm back in sync, it ran great for two weeks but then stopped.
Re wound and off it went, not a full 8 winds as from empty, but only 5 winds, looking at the escapement it will run fine with a little shake but then slowly come to a stop, not  a sudden stop but a slow stop. Now I did put a small amount of oil on a few of the escape wheel teeth so as to allow it to spread throughout due course of the movement running. I don't have any FIX O DROP at the moment, could this be the cause of the stoppage, ie the oil running away off the parts, or the big question should I oil the escape wheel teeth ( only a few) or not oil and allow the movement to run?
I remember these movements and quite good they are to. Sounds nothing to do with oil and escapement. I suggest you take a good look at the large wheel pivots. That is the wheel that runs next to the barrel, the 8 day movements have a powerful spring so the large wheel takes all the wear, it normally shows in the bush or the pivot or both have worn, you need to check both sides, I’ll be very surprised if any of the other train holes or pivots are worn. As it doesn't go its full 8 days tells me the power isn't getting through.
  • 5 weeks later...
On 12/7/2017 at 7:34 PM, oldhippy said:
a tiny little oil on a few excape wheel teath, the motion of the work will spread the oil to the rest of the teath and to the pins on the pallets and it wont form a blob at the bottom of the pallets.
Sorry if this is a stupid question but is this also a suitable method for oiling a watch. seems way easier than oiling the pallet fork directly.
watches require special oils (see  many posts on THAT).  oil types used on clocks are not that  special.   vin
Can we get a clarification perhaps a picture of your clock? Reason for the clarification you're discussing a jeweled movement not always found in clocks but sometimes found in very large watches that are used in clocks.
Then whether or not you used FIX O DROP  Is not going to be a problem. Most watch people don't use it and they get along just fine the oil isn't going to spread that fast providing all the surfaces are clean.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes.
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
