I can't remove this last wheel!
Winston
9 minutes ago, Winston said:
I have to pull on the shaft coming thrue the pignon?
You pull the pinion. I don't have a cannon pinion tool so use a sturdy pair of tweezers - like those in your first picture.
It's important not to squash the walls of the cannon pinion, so grip it without too much pressure, and lift vertically.
2 minutes ago, frenchie said:
If the watch hasn't been serviced in a while, it might take some effort. The important part is to not squeeze too hard if you use tweezers!
A canon pinion remover is a good tool to have around, and is somewhat cheap.
I have one of the cheap tools - like the hand remover tool, but it never seems to grip the pinion correctly. Maybe I need to do a bit of filing on it. The 'proper' tool is about £70
You can use the "presto" type hand removing tool as a cheaper alternative to a dedicated cannon pinion remover. It will pull the cannon pinion very neatly and will be a vertical pull, no risk of damage to the centre wheel arbour. You can dress the jaws of the tool for a perfect fit, they are only a couple of pounds from China.
I have a Bergeon cannon pinion removal tool, but still sometime use a presto tool as the Bergeon does not work on small cannon pinions.
Whilst tweezers will work, I think they are not ideal as you risk putting some stress on the centre wheel.
Thanks to everyone :) I am just starting in this amazing hobby. This a movement I got for 3$ to practice. I managed to disassemble it then reassemble it and make it run. Now I am going to disassemble it again, clean it and oil it while putting it back! Here are some pictures so you can the movement when it's stripped and when I started to clean parts :)
15 hours ago, jguitron said:
£70 may be better than crimping the pinion while trying to pull it off and then having to either buy another one if still available or spend some effort in restoring it.
Good luck!
You are correct of course. You prompted me to dress the jaws of the cheap "presto" type tool I have - as OIi mentions above.
And now they work really well !
Another option to remove the cannon pinion if you can't afford the remover is a pin vice. Just make sure you hold it straight and pull up, not to the side else you may break the shaft on the centre wheel.
    • When you move the index which changes the timing from an extreme fast to an extreme slow, is there a big change in beat error? Obviously there will be a big change in timing. If there is a big difference in BE then this is strongly inferring the the end-curve of the hairspring isn't set correctly or/and the collet is central to the jewel on the balance cock, because the hairspring that is breathing between the curb pin and boot is being pushed and/or pulled when you move the index from left to right. Also not having the hairspring set correctly can dramatically reduce the amplitude. A quick check is to take power off the movement and move the index from extreme fast to slow and with high magnification see if the hairspring sits nicely between the curb pin and boot at all times (give the balance a spin and watch the hairspring - has it got total freedom?) or if it moves by being pushed or pulled by the curb pin or boot. I'm guessing it is the latter. I think that may be a possibility to your problem.
    • I can't get windingstens.com to open but you need a  few measurements.
    • All Done, Here are the finished pictures: This one shows the generic "one-size-fits-all" base which accepts the bespoke rings - notice that the parametric movement OD (27.40 mm) automatically prints on the ring 🙂 From another angle: Here is the ring about to go into the base: And finally the base and ring together: Here it is next to a pen for scale: On my system with 20% fill each ring will take about 18 mins to print, but I am sure this could be optimised: Here is the screenshot of the spreadsheet in FreeCAD, you just need to change one value to create the ring in cell C3, (the base doesn't need any changes). I'll upload the files to printables in due course, but here whey are as a fake pdf, please change the .pdf to .zip to make the file work once downloaded: Modular Movement Holder.pdf Any feedback welcome!     I'm also going to make a parametric ring insert for rectangular/oval movements - but I just finished a parent teacher evening so too tired now 🙂
    • I'm going to give that a go next time, thanks for a great idea @rossjackson01 One of my students uses this tool and swears by it https://www.cousinsuk.com/product/wheel-hand-roller-remover-bergeon?code=W1851 which is very like getting two sticks of pegwood under the wheel and rolling them in your fingers so they create a slight prying from underneath motion, I suppose. Maybe bind one end of the two sticks of pegwood so they are like tweezers.
    • Thank you. I spent a lot of time on that.   It never ceases to amaze me that there are so many slight adjustments that can be made to the chronograph mechanism through setting the eccentric studs to get them all to a concerto, like an orchestra with everything in time and to its most optimum. Understanding that setting one stud to the desired effect may throw another out is the fun of working on vintage chronographs. Great pic of the 3133 dart tooth interaction and tilt of the tooth. I love working on 3133s. Slightly better than the 7733 in my opinion and you get a date at 6!
