French Mantle (Slate) Clock Movement
Folkvisor
Hi
I have a French movement to repair. It is much like the one in the attached video but I am just wondering if anyone has any advice. It was fully wound when I received it but it doesn't work. I'm thinking it is probably dirty and may simply need cleaning.
All advice is welcome. (Someone told me I should reassemble it and give it back...)
Thank you
Dave
Hi everyone
It is a strike movement. It looks like it's pretty straight forward and I really think it only needs to be cleaned and oiled.
I would like to know if there are any pitfalls re dismantling the thing I should know about beforehand.
A quick overall inspection didn't show anything broken or even out of place. I'm sure it's never been cleaned - ever - so that is more than likely its main problem.
No one in the family can ever remember it running. Whatever that means...
Thank you for all your answers. I hope I have answered the questions fully enough.
Dave
In that case my advice would be to take plenty of pictures and when you’ve put it back together and the strike doesn’t line up with the time, ask Old Hippy or Clockboy for help.
Make sure you don’t mix up the two barrels and springs - often these will have been marked g and s by previous repairers.
French striking clocks mainly have two types of striking, rack and count wheel, the count wheel tends to be on the outside of the back plate.
After removing the hands and dial from the movement, you need to let the power down on both sides, you can do this using the key and open the click from the click wheel in stages until all power is down. These movements are made of a high standard of brass and steel, if you are not familiar with this type take notes and photos of where the parts go, it’s the strike side you need to pay attention to the wheels with pins. Everything that comes apart take apart, do not touch or remove the fan adjuster. As someone has said, keep the barrels separate from each other. Normally these movements just need polishing and cleaning, some need re-bushing, so check the pivots. If the pivots are worn, you will need a lathe to make good. All brass parts should be polished and all screws should be cleaned up and polished using needle files and emery again a lathe is normally used, you can do this by hand but it’s a bit of a hit and miss.  The screws are then blued and quenched in oil, using oil gives them a nice shine. Polishing the brass, I always used brasso, apply brass to a soft brush, and use a soft cloth when polishing the plates and other plate parts and pendulum. All parts when polished and washed out are then dried. I used fine sawdust. Then all brass parts are chalked brushed using French chalk and a clean chalk brush. Depending on your skills when it comes to re-bushing you might like to make your own or you might buy the already made ones. Make sure all pivots are in good order and burnished. Remove any burr from the two arbors and polish the ends that show in the key holes.   If you need any help just ask, I expect I have missed something.
Spot on advise.
Spot on advise.
Here are a few things I’ve missed.
Check the s/spring if it needs replacing do so with a new one with brass like ends not those dreadful plastic things. Clean and tidy/polish with emery, the regulator square which shows just above 12 on the dial and the end on the centre wheel where the hands are pinned. Always fit new steel pins and when you make the cut off tidy and round off with a file. When you pin the main plates make the pins all the same size and tidy and the plate the movement is pinned too. Don’t forget to polish the gong and treat the screws as I have already explained, if it’s a bell you can polish this on a mop using jewellers rouge then wash out in soapy water, the two case screws that hold the movement into the case clean them up but do not blue.
43 minutes ago, Folkvisor said:
Thank you for this.
By s/spring I understand you to mean the 'striking' mechanism spring.
Where can I buy the fastening pins? The pins on this clock are not in very good shape.
Dave
https://www.cousinsuk.com/product/steel-brass-assorted?code=P47506
http://www.m-p.co.uk/muk/parts/clock-pins.htm
https://www.hswalsh.com/categories/brass-and-steel-clock-pins
eBay (search clock pins)
    • Thanks for the help guys! VWatchie I already found your thread but I'll check it again. Nice to know about acetone, I still have to get the shellac off since I made a little mess. I adjusted the jewel, put new shellac (the so called soldering technique, pallet tool too hot this time so the shellac "wire" melted in air before getting in contact with jewels or fork) rinsed the pallet fork and put it back dry. Amplitude is now in the 240-250 range that I expected in the first place. I guess there's enough oil in the escape wheel teeth already but I'll check that later. The mainspring was pretty beaten so a new one would probably boost the amplitude even further. Nice to learn new things. Now I have another thing to look for while disassembling. I wonder if the watch left the factory that way.
    • Would be interesting to see it 🙂
    • These are all American movements (with the exception of the "Rubis"), and are all almost certainly "negative set" which means the stem is part of the case. So it's normal that they are all missing- they are with their cases. You will need male square bench keys to wind/disarm them. Vintagewatchstraps has a great writeup on the different systems. But basically, any American "x" size movement will fit any case for that size, possibly with some adjusting of the stem position. With Swiss movements, there is some interchangeability between calibers, usually within the same maker's range, but not really overall- there are thousands of different stems out there.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
