French Mantle (Slate) Clock Movement
Folkvisor
Smooth snail wheels are machined in such a way that with each hour the rack drops down a tooth at a time, the only difference is its more difficult to see and judge. With many movements the minute, hour and sub wheels are marked by a small punch mark, have these lined up and all should be correct.
The strike wheels with pins need to be in the correct order. Imagine a clock face and you are looking at it.  The wheel next to the fly should have the warning pin at about 9 45 or 9 50. The gathering pallet wheel with its pin should be resting on the stop leaver inside the movement that is the lever just above the hammer lever. The strike wheel (the one with loads of pins in) should be clear and not in any lifting position of the hammer lever. The gathering pallet should be attached onto the extended pivot at about 10 to the hour (you can always move it if need be) You should have two pins set in the back of the minute wheel, which lift the lever (red arrow) this will lift part (green arrow)The rack will drop down onto the snail, these levers at the time of working also release the wheel next to the fly wheel with the single pin against the guard which is attached to the lever  (red arrow) inside the window (blue arrow). This is called the warning, note the hammer at this stage should not be lifting. When the clock is at the hour, lever (red arrow) will clear the pin on the minute wheel, the guard will also drop causing the strike wheels to rotate. Depending where the rack drops onto the snail will depend how many times it strikes. If there is no punch marks on the wheels, you need to have the rack dropping down for 12 0’clock about here (yellow arrow)
I know the photo I’m using is for a platform and not a pendulum, the striking is the same.   If you need more info just ask or if you don't understand.
Edited by oldhippy
That's a new one for me I have never seen a smooth snail wheel before. As you say it must be difficult to  get the sequence correct.
I guess I just lucked out getting to work on a clock with a smooth snail wheel.
Have you any idea how old such a clock would be? Ballpark...
It is impossible to get this kind of information in books or on the net. If not for this site there would be nothing at all.
You should write a book.
Edited by Folkvisor
Now to regulate it. Providing the springs are good this should keep very good time 1 minute in a week ether way. Once you learn about the striking, these clocks are quite easy to work on. What takes the time is the polishing, cleaning, and bluing screws.
  Happy to help anytime.
I'm still trying to get it to speed up a little more. small increments. I'm sure I'll be pretty slow when I'm 120 or so years old too.
The pins on the minute wheel aren't any too long so I have to be really careful about pulling off the minute hand or it will pull the pins away from the lifting lever. I'm not sure that I can do anything about that except making sure the pins are in place before I put the clock together.
I'm learning slowly. Someone did a lot of thinking figuring this stuff out!
Yup. I've found about wheel alignment from experience. There's lots to learn. I'd like to get a French Clock of my own to work on so I can learn more about them.
They want me to fix a grandfather clock but it doesn't look much different than my mantle clock just weights instead of springs and a moon phase 'clock'. Also,  there's lots of info on line about them...unlike French clocks.
Try and get your hands on an 17th or 18th century 8day English Longcase (grandfather) clock. They are wonderful to work on, in my time I must have restored hundreds. French carriage clocks are interesting too, because after all that cleaning, polishing and bluing screws people actually see the clock working, some do have complicated striking.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from .
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
