French Mantle (Slate) Clock Movement
Folkvisor
Hi
I have a French movement to repair. It is much like the one in the attached video but I am just wondering if anyone has any advice. It was fully wound when I received it but it doesn't work. I'm thinking it is probably dirty and may simply need cleaning.
All advice is welcome. (Someone told me I should reassemble it and give it back...)
Thank you
Dave
Hi everyone
It is a strike movement. It looks like it's pretty straight forward and I really think it only needs to be cleaned and oiled.
I would like to know if there are any pitfalls re dismantling the thing I should know about beforehand.
A quick overall inspection didn't show anything broken or even out of place. I'm sure it's never been cleaned - ever - so that is more than likely its main problem.
No one in the family can ever remember it running. Whatever that means...
Thank you for all your answers. I hope I have answered the questions fully enough.
Dave
In that case my advice would be to take plenty of pictures and when you’ve put it back together and the strike doesn’t line up with the time, ask Old Hippy or Clockboy for help.
Make sure you don’t mix up the two barrels and springs - often these will have been marked g and s by previous repairers.
French striking clocks mainly have two types of striking, rack and count wheel, the count wheel tends to be on the outside of the back plate.
After removing the hands and dial from the movement, you need to let the power down on both sides, you can do this using the key and open the click from the click wheel in stages until all power is down. These movements are made of a high standard of brass and steel, if you are not familiar with this type take notes and photos of where the parts go, it’s the strike side you need to pay attention to the wheels with pins. Everything that comes apart take apart, do not touch or remove the fan adjuster. As someone has said, keep the barrels separate from each other. Normally these movements just need polishing and cleaning, some need re-bushing, so check the pivots. If the pivots are worn, you will need a lathe to make good. All brass parts should be polished and all screws should be cleaned up and polished using needle files and emery again a lathe is normally used, you can do this by hand but it’s a bit of a hit and miss.  The screws are then blued and quenched in oil, using oil gives them a nice shine. Polishing the brass, I always used brasso, apply brass to a soft brush, and use a soft cloth when polishing the plates and other plate parts and pendulum. All parts when polished and washed out are then dried. I used fine sawdust. Then all brass parts are chalked brushed using French chalk and a clean chalk brush. Depending on your skills when it comes to re-bushing you might like to make your own or you might buy the already made ones. Make sure all pivots are in good order and burnished. Remove any burr from the two arbors and polish the ends that show in the key holes.   If you need any help just ask, I expect I have missed something.
Spot on advise.
Spot on advise.
Here are a few things I’ve missed.
Check the s/spring if it needs replacing do so with a new one with brass like ends not those dreadful plastic things. Clean and tidy/polish with emery, the regulator square which shows just above 12 on the dial and the end on the centre wheel where the hands are pinned. Always fit new steel pins and when you make the cut off tidy and round off with a file. When you pin the main plates make the pins all the same size and tidy and the plate the movement is pinned too. Don’t forget to polish the gong and treat the screws as I have already explained, if it’s a bell you can polish this on a mop using jewellers rouge then wash out in soapy water, the two case screws that hold the movement into the case clean them up but do not blue.
43 minutes ago, Folkvisor said:
Thank you for this.
By s/spring I understand you to mean the 'striking' mechanism spring.
Where can I buy the fastening pins? The pins on this clock are not in very good shape.
Dave
https://www.cousinsuk.com/product/steel-brass-assorted?code=P47506
http://www.m-p.co.uk/muk/parts/clock-pins.htm
https://www.hswalsh.com/categories/brass-and-steel-clock-pins
eBay (search clock pins)
    • Thanks all.   Movement is a Helvetia 800C. Don't know any history e.g. if the broken mainspring is original. Watch was bought recently as non-working. Really interesting piece that Jon, thanks. I'd only been thinking of length relating to power reserve. I don't have a mainspring winder (yet) so I'd like to avoid winding the spring into the barrel by hand. The old spring measures at 1.60 x .11 x ~290. Sorry, can't be exact on the length. The piece I still have is 275, but the second piece escaped during measurement. Best measurement I had for it was ~13. The micrometer does zero accurately so I'm pretty confident of the .11 Also, I'm getting the barrel ID at 9.5 on a vernier. I'm now wondering about going with a .11 spring? Given all of the above, maybe 1.60 x .11 x 300 x 9? Any thoughts? Cheers.
    • Funny that you should bring this up. I was thinking about it just the other day. What happens if something happens to @Mark? The social bit is fantastic and I would miss it dearly, but I worry even more about the content. Together we have created a gold mine of information which would be more or less irreplaceable if the site should disappear. People (often with a lot of knowledge) come and go. I sometimes wonder what happened to them and miss them. We have no idea unless we have some private contact information. When I was new here I saw a lot of posts by @Lawson. He had a true fire in his heart for horology and was asking for an apprenticeship in his signature. I found that very inspiring and often wondered what happened. Is the fire still burning? Did he get an apprenticeship?
    • I dont like to give up things that i enjoy Tom.  So my next question is how are we going to prepare for that inevitability and what are we going to do about it. Its not just about funding it but I did pick up on something that Mark said once. It doesnt run on fresh air , what if it becomes a burden or an unnecessary cost or for any other reason that i wont get into. We all know life can change in an instant, my life has been so up and down for about 8 years and was only just beginning to level itself out.
    • What I especially like is that this forum is not full of ads. There are some but they're not interfering. No ads between posts like one certain big watch forum. Browsing is also very easy and light for a mobile device. I'm glad there's still room for old school forums like this. I'm a member in many facebook groups but there's really no long term discussion and if you see an interesting post you might never find it again if needed.
