Problems with polishing a watch case
@bojan1990 I was thinking about your original post and someting occurred to me. You said you moved from P220 to P800 in 1 step. This may be part of your problem as this is a big jump and you will have to keep going with 800 for a long time to remove the marks from 220. Try at least 1 intermediate stage at 400 grit. Alternatively you could do 320 and then 600 before you get to 800. I think this may help.
Thanks. I did the sanding with water and I saw the difference immediately. Next time I will try to go slower up the grades (I have 220, 320, 550, 800, 1000, 1500 and these Silicon Carbide grades which still nobody knows what they exactly are). However, after polishing with 1500, I moved to polishing paste, but I am still not happy with results. The surface is quite smooth, but under bright like, I can see very very thin scratches. My camera is bad, and my photo skills are bad as well, but I hope you could see what problem I have:
And if you were to measure it, you could be saddened  by finding the entire case now half a mm smaller, after all that wild grinding and sandpaper parading.
Both issues would have been easily avoided by, let me say it loudly, buffing, and a $10 rotary tool and felt wheels.
Edited by jdm
No, I have only a little stick with fine cloth with a little bit of polishing paste.
Yeah, it's not enough I'm afraid. You really need a pendant drill/rotary tool/polishing mop to really attack that surface. If you could get hold of a dremel drill of some type, that would be a step in the right direction. Then get yourself a firm buffing/polishing wheel. Then you need a hard metal polishing compound like Hyfin or the blue colour Luxi bar. Use the compound on the wheel and go over the surface until the scratches are gone.
Sent from my SM-G935F using Tapatalk
On 11.11.2017 at 11:30 AM, hir3na5hra said:
Something like this to go on the dremel.64cee5b838331d872af376a9ee907636.jpg
Is is possible to use a regular electric hand drill and put the buffing wheel on it? I just do not have place where to put the fixed machine. The main problem is of course fixation - with hand drill I would (probably) need to put the drill in my right hand, and watch case in the other. What kind of pressure I need when doing this?
Although technically it's possible, it sounds a little awkward. Your control might not be that great especially if you're trying to support a big hand drill. You need something small yet powerful to control the movement. Control is hugely important.
A dremel type device might not be all that powerful, but it's ideal for precision work... Which you need.c36edd52af71ecdf9d8cf139ebdc0b08.jpg
Yes. You can, for example, use something like that
https://www.aliexpress.com/item/Universal-Clamp-on-holder-hanger-stand-Electric-Drill-Stand-Dremel-Rack-Multifunctional-bracket-stand-clamp/32683793943.html
However, that works better with a 5cm or bigger wheel, when doing aggressive buffing for deep scratches and dings. For anything else it's better to use a smaller tool and wheel, but I would recommend a vice mount anyway. Pressure applied depends on the job, and you learn with practice, but in general must be so the rotation doesn't slow down noticeably.
    • Yes, as watch repairers we never ever use force, we use percussive persuasion! 🤣
    • I have a barrel bridge arbor bearing that needs a slight reduction. I have never closed a barrel bridge arbor hole before and my staking set has a very limited number of doomed punches and most of them are too small (go through the hole) or too short to fit in the lower section of my inverto-style Boley & Leinen staking tool. So, I'm considering ordering a few doomed punches from CousinsUK. My question is what sizes I should order? Is there a rule of thumb relating to the hole diameter? I too worried that reducing the hole size would increase the end-shake. Especially as Kalle Slaap talks about end-shake at the end of the video at 7:43, but then he just glosses over it by saying "You can just gently push the material back in", which I don't get at all 🤔 Anyway, I feel a lot less worried now after having seen @mikepilk's excellent illustration. Thanks!
    • If you have access to a 3D printer, here is my design I did a few weeks ago:
    • I finished my polisher yesterday, and just tried it out. I'm surprised how easy it is to get a good result - just a couple of minutes. I thought it was going to be more difficult - a nice surprise as most things in watchmaking are harder than you expect. I bought self adhesive 3M lapping film https://www.cousinsuk.com/product/film-lapping-3m-261x266x , 9, 3 and 1 micron, and stuck it to sheets of glass. The 9 micron is course enough to remove large scratches.  I'm glad I used the M6 thumb screws as the large heads allow for small adjustments.
