Problems with polishing a watch case
@bojan1990 I was thinking about your original post and someting occurred to me. You said you moved from P220 to P800 in 1 step. This may be part of your problem as this is a big jump and you will have to keep going with 800 for a long time to remove the marks from 220. Try at least 1 intermediate stage at 400 grit. Alternatively you could do 320 and then 600 before you get to 800. I think this may help.
Thanks. I did the sanding with water and I saw the difference immediately. Next time I will try to go slower up the grades (I have 220, 320, 550, 800, 1000, 1500 and these Silicon Carbide grades which still nobody knows what they exactly are). However, after polishing with 1500, I moved to polishing paste, but I am still not happy with results. The surface is quite smooth, but under bright like, I can see very very thin scratches. My camera is bad, and my photo skills are bad as well, but I hope you could see what problem I have:
And if you were to measure it, you could be saddened  by finding the entire case now half a mm smaller, after all that wild grinding and sandpaper parading.
Both issues would have been easily avoided by, let me say it loudly, buffing, and a $10 rotary tool and felt wheels.
Edited by jdm
No, I have only a little stick with fine cloth with a little bit of polishing paste.
Yeah, it's not enough I'm afraid. You really need a pendant drill/rotary tool/polishing mop to really attack that surface. If you could get hold of a dremel drill of some type, that would be a step in the right direction. Then get yourself a firm buffing/polishing wheel. Then you need a hard metal polishing compound like Hyfin or the blue colour Luxi bar. Use the compound on the wheel and go over the surface until the scratches are gone.
Sent from my SM-G935F using Tapatalk
On 11.11.2017 at 11:30 AM, hir3na5hra said:
Something like this to go on the dremel.64cee5b838331d872af376a9ee907636.jpg
Is is possible to use a regular electric hand drill and put the buffing wheel on it? I just do not have place where to put the fixed machine. The main problem is of course fixation - with hand drill I would (probably) need to put the drill in my right hand, and watch case in the other. What kind of pressure I need when doing this?
Although technically it's possible, it sounds a little awkward. Your control might not be that great especially if you're trying to support a big hand drill. You need something small yet powerful to control the movement. Control is hugely important.
A dremel type device might not be all that powerful, but it's ideal for precision work... Which you need.c36edd52af71ecdf9d8cf139ebdc0b08.jpg
Yes. You can, for example, use something like that
https://www.aliexpress.com/item/Universal-Clamp-on-holder-hanger-stand-Electric-Drill-Stand-Dremel-Rack-Multifunctional-bracket-stand-clamp/32683793943.html
However, that works better with a 5cm or bigger wheel, when doing aggressive buffing for deep scratches and dings. For anything else it's better to use a smaller tool and wheel, but I would recommend a vice mount anyway. Pressure applied depends on the job, and you learn with practice, but in general must be so the rotation doesn't slow down noticeably.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
