Problems with polishing a watch case
Hello,
currently, I am experimenting with polishing an old watch case made out of stainless steel. I polish everything with hand, I am basically tried to follow the tutorial made by Nickolas Hacko here http://www.clockmaker.com.au/rolex/rolex_case_polishing.html I started with P220, moved to P800 and P1500. However, the scratches were still visible, so I continued with Silicon Carbide 1200/4000 (I would say this is the finest sandpaper I had). After that, I proceeded with the polishing paste, but the little scratches were still visible (not at the whole surface, but parts of them). I also noticed that the flat parts (side surfaces) were better polished compared to the front (oval) surfaces of the watch. Probably due to the straighter moves I had to make in this area. Any ideas what to do next or where I made mistake?
Thanks!
Never use abrasive paper on a watch case, is very bad for a (self appointed) watchmaker to suggest that. As mentioned, buffing and polishing with a rotary tool is the proper technique. There are few more valid YT videos on the subject.
4 minutes ago, Geo said:
Why?
Because it's not needed. As shown in the video above, buffing does not just remove material, but it also moves it.  It is a much less aggressive method with a reduced number of passes, and associated mess.
That's fine if you have both the machinery and skill to use it!   I would like to inform folk it is so easy to round sharp edges and loose the original profile..........very quickly.
Using various grades of wet or dry paper, a piece of wood with metal polish and finally a silver polishing cloth will result in a black polish finish.  Using this method (it does take some time) there is far less chance of damaging original profiles.  More importantly,  by using this method you can carefully reclaim profiles that have been damaged.  I have seen more damage caused by folk using buffs that anything, and not always by amateurs.
Machinery consist in an rotary tool or even a just a drill , which you can jury rig to a vice, even a proper suppor will cost few Euros.
For the rest I don't agree with using abrasives, which remove more material which can never be put back. Of course, if at the end of the process one finds that polishing compound works better when applied by hand, that is fine, but so far I've achieved the best results with small felt wheels, some are knife shape, etc.. Cousins has a lot of these.
The supposed damage to sharp edges is a vastly exaggerated issue, for one not all cases have sharp edges, or damage near to the edges. I've successfully repaired or refinished tens of case, and some were badly damaged. Of course as in everything which involves manual skills, one has to use judgement and control of the technique.
Edited by jdm
3 hours ago, Marc said:
Buffing/polishing compounds are abrasives.
Of course they are. If you read my postings and watch the video (by the premier watchmaking school in the USA) above, you will notice that the idea is to abrading less, and move material with heat. These are the main advantages of buffing over a pure abrasive action.
And i think michael boltons methods are the same as yours, i like the way he works, keeping the lines sharp, by hand .
Buffing with a big machine,are in my opinion, just too dangerous, and i dont want to end up with a lump of shiny metal, with no lines !!
And btw its always a good idea to practise on a scrap case before you let the abrasive sink into valuable items ! Been there done that ! [emoji849]
Restored by myself :).
Had deep dings on bezel and case side, but made one more happy owner now.  Something which I still need to perfection is the very peculiar non-directional satin finish that is proper for the top of lugs, and the circular finish on the case back, for which a lathe will be enough.
Edited by jdm
On 10/30/2017 at 4:08 PM, Latvas said:
Try looking at michael bolton on youtube, i learned a lot from him, emoji1303.png
Thanks, I will take a look on that. However, I do not have any machine available. Hope I can do something only by hand for now.
A bit like oils, this is one of those hot button issues.
I don't think anyone is necessarily 'wrong' but my perspective - whatever it's worth - is much in line with JDMs, proper/best practice for case/bracelet refurbishment relies on buffing, which removes microscopic amounts of material and simply moves the vast majority of the metal into its original shape, when that's an option i find it hard to justify sanding and removing significant amounts of metal to remove the appearance of scratches. It does have risks and skill/knowledge requirements like a lot of things, however.
If you have the knowledge, skill, and experience there are very few cases (no pun intended) where it would be unavoidable for you to smooth a sharp edge, mostly on bracelets i think.
What some people don't realize is that you can sometimes even buff a sharp edge back, at least to an extent, though you may not exactly be able to shave with it. :D
Edited by Ishima
I prefere to buff but it does make a lot of mess which is a real problem for me as I only have a small workshop.  I therefore tend to just polish cases with a "Proxon" and different grades of  Dialux waxes. I get really some nice finishes but it does not remove dings.
That is exactly what I do, but I switch to a drill with a 5cm wheel for the deepest scratches and dings. You need orange Dialux for buffing. Grey works too to a limited extent. To limit mess place vice, tool and all in a cardboard box and work inside there.
Hello,
Thanks!
Hi. I think after getting rid of most of the scratching with the rough grades and moving down to P1500, move on to the buffing wheels. Use a calico mop with Hyfin. It polishes steel up immaculately. [emoji16]
Sent from my SM-G935F using Tapatalk
12 minutes ago, hir3na5hra said:
Hi. I think after getting rid of most of the scratching with the rough grades and moving down to P1500, move on to the buffing wheels. \
Again... do not use abrasive paper on watches cases, as it removes material and make you work longer and unnecessarily.
If you want to remove heavy scratching from steel, it's absolutely necessary. I've been doing it for years. How can you possibly just shine over scratches! Are you saying companies like Rolex, Richard Mills and Patel Phillips never grind away scratches before polishing? Let me tell you that they do as I've worked with them.
If you want to remove heavy scratching from steel, it's absolutely necessary. I've been doing it for years. How can you possibly just shine over scratches! Are you saying companies like Rolex, Richard Mille and Patek Phillipe never grind away scratches before polishing? Let me tell you that they do as I've worked with them.
Haha! Patel Phillips
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
