Problems with polishing a watch case
Hello,
currently, I am experimenting with polishing an old watch case made out of stainless steel. I polish everything with hand, I am basically tried to follow the tutorial made by Nickolas Hacko here http://www.clockmaker.com.au/rolex/rolex_case_polishing.html I started with P220, moved to P800 and P1500. However, the scratches were still visible, so I continued with Silicon Carbide 1200/4000 (I would say this is the finest sandpaper I had). After that, I proceeded with the polishing paste, but the little scratches were still visible (not at the whole surface, but parts of them). I also noticed that the flat parts (side surfaces) were better polished compared to the front (oval) surfaces of the watch. Probably due to the straighter moves I had to make in this area. Any ideas what to do next or where I made mistake?
Thanks!
Never use abrasive paper on a watch case, is very bad for a (self appointed) watchmaker to suggest that. As mentioned, buffing and polishing with a rotary tool is the proper technique. There are few more valid YT videos on the subject.
4 minutes ago, Geo said:
Why?
Because it's not needed. As shown in the video above, buffing does not just remove material, but it also moves it.  It is a much less aggressive method with a reduced number of passes, and associated mess.
That's fine if you have both the machinery and skill to use it!   I would like to inform folk it is so easy to round sharp edges and loose the original profile..........very quickly.
Using various grades of wet or dry paper, a piece of wood with metal polish and finally a silver polishing cloth will result in a black polish finish.  Using this method (it does take some time) there is far less chance of damaging original profiles.  More importantly,  by using this method you can carefully reclaim profiles that have been damaged.  I have seen more damage caused by folk using buffs that anything, and not always by amateurs.
Machinery consist in an rotary tool or even a just a drill , which you can jury rig to a vice, even a proper suppor will cost few Euros.
For the rest I don't agree with using abrasives, which remove more material which can never be put back. Of course, if at the end of the process one finds that polishing compound works better when applied by hand, that is fine, but so far I've achieved the best results with small felt wheels, some are knife shape, etc.. Cousins has a lot of these.
The supposed damage to sharp edges is a vastly exaggerated issue, for one not all cases have sharp edges, or damage near to the edges. I've successfully repaired or refinished tens of case, and some were badly damaged. Of course as in everything which involves manual skills, one has to use judgement and control of the technique.
Edited by jdm
3 hours ago, Marc said:
Buffing/polishing compounds are abrasives.
Of course they are. If you read my postings and watch the video (by the premier watchmaking school in the USA) above, you will notice that the idea is to abrading less, and move material with heat. These are the main advantages of buffing over a pure abrasive action.
And i think michael boltons methods are the same as yours, i like the way he works, keeping the lines sharp, by hand .
Buffing with a big machine,are in my opinion, just too dangerous, and i dont want to end up with a lump of shiny metal, with no lines !!
And btw its always a good idea to practise on a scrap case before you let the abrasive sink into valuable items ! Been there done that ! [emoji849]
Restored by myself :).
Had deep dings on bezel and case side, but made one more happy owner now.  Something which I still need to perfection is the very peculiar non-directional satin finish that is proper for the top of lugs, and the circular finish on the case back, for which a lathe will be enough.
Edited by jdm
On 10/30/2017 at 4:08 PM, Latvas said:
Try looking at michael bolton on youtube, i learned a lot from him, emoji1303.png
Thanks, I will take a look on that. However, I do not have any machine available. Hope I can do something only by hand for now.
A bit like oils, this is one of those hot button issues.
I don't think anyone is necessarily 'wrong' but my perspective - whatever it's worth - is much in line with JDMs, proper/best practice for case/bracelet refurbishment relies on buffing, which removes microscopic amounts of material and simply moves the vast majority of the metal into its original shape, when that's an option i find it hard to justify sanding and removing significant amounts of metal to remove the appearance of scratches. It does have risks and skill/knowledge requirements like a lot of things, however.
If you have the knowledge, skill, and experience there are very few cases (no pun intended) where it would be unavoidable for you to smooth a sharp edge, mostly on bracelets i think.
What some people don't realize is that you can sometimes even buff a sharp edge back, at least to an extent, though you may not exactly be able to shave with it. :D
Edited by Ishima
I prefere to buff but it does make a lot of mess which is a real problem for me as I only have a small workshop.  I therefore tend to just polish cases with a "Proxon" and different grades of  Dialux waxes. I get really some nice finishes but it does not remove dings.
That is exactly what I do, but I switch to a drill with a 5cm wheel for the deepest scratches and dings. You need orange Dialux for buffing. Grey works too to a limited extent. To limit mess place vice, tool and all in a cardboard box and work inside there.
Hello,
Thanks!
Hi. I think after getting rid of most of the scratching with the rough grades and moving down to P1500, move on to the buffing wheels. Use a calico mop with Hyfin. It polishes steel up immaculately. [emoji16]
Sent from my SM-G935F using Tapatalk
12 minutes ago, hir3na5hra said:
Hi. I think after getting rid of most of the scratching with the rough grades and moving down to P1500, move on to the buffing wheels. \
Again... do not use abrasive paper on watches cases, as it removes material and make you work longer and unnecessarily.
If you want to remove heavy scratching from steel, it's absolutely necessary. I've been doing it for years. How can you possibly just shine over scratches! Are you saying companies like Rolex, Richard Mills and Patel Phillips never grind away scratches before polishing? Let me tell you that they do as I've worked with them.
If you want to remove heavy scratching from steel, it's absolutely necessary. I've been doing it for years. How can you possibly just shine over scratches! Are you saying companies like Rolex, Richard Mille and Patek Phillipe never grind away scratches before polishing? Let me tell you that they do as I've worked with them.
Haha! Patel Phillips
    • Haha. You're just in a wicked mood today John 😅
    • Heres my watch of today, a Smith 13'" RY . My missus bought me this for this Valentines day a bargain 14.99 with a reduction, the seller has occasional 20% off offers now and then so it was about 15ish with delivery. I love Smiths and i love bulleye dials, this is my first one. The watch arrived non working as stated and i knew what was inside and what would be against me, but i enjoy a challenge, we dont expect a lot if anything from pin pallet movements. A balance pivot was broken and i didnt have another staff but i did have another RY with a battered dial so i robbed the balance and tweaked it around to make it work apart from that mostly just a good clean and relubrication. Keyless works are pretty rough by design and the crown is a bugger to get in and out with the dial on, the setting lever hits the dial before it releases it, so a little mod is needed to help that along. Major problem was the pins on the lever were quite worn which make the old tg have a snow storm fit. Its a similar read for most pin pallets, these were brass as was the escape wheel. But perseverance is me, i didn't change the pins but i did spend some time dressing and polishing the worn areas which improved the trace a lot with some straightish lines 😅 and a beat error of .5 . Not sure what the lift angle should be on these and i Wasn't in the mood to work it out and who believes timegraphers anyway, but at the default 52° it runs with 260ish full 210 after 24 hours dial down , the verticals rates were pretty much all over place. So lets just put it in it's superlight aluminium case and see what happens. Been wearing it now for 3 weeks and it's consistently losing around 1.5  minutes a week winding each morning i think pretty good for an old pin pallet watch. I just love this dial, thanks wifey heres my Valentine's gift for yer sweetie x
    • I have a PDF below that will help. The problem was the PDF wasn't designed for this purpose it was designed to tell you what size watch you  have. Then it doesn't take into account movements come conceivably in different thicknesses.   watch-ligne-size-chart.pdf
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
