Moebius 9034/2 or Moebius 9000/2 ?
Tmuir
There are lots of threads about which oil to use on mechanical watches, but not many on the discussion for quartz watches.
I don't plan to do too many quartz watches, so would prefer to only buy one quartz watch oil. (if possible)
The ETA955.112 technical sheet recommends Moebius Synthetic 9034/2, but then we have Moebius 9000/2 which is specifically made for quartz watches.
If I was to only buy one which one would you recommend?
9000 is fine with plastics but I don't know about 9034, I also see the two oils have different viscosity too, and I think the 9034 being the lighter (finer) oil
To add to the confusion if you look at the newest tech sheet for ETA955.112 They have another oil 9014. Then I have noticed that the 9000 quartz oil doesn't always appear in the tech sheets for lubricating quartz watches?
The problem with horological lubrication is to try to find anything that resembles meaningful specifications that we can use. So 9014 has a viscosity of 98cts 20°C. Not the best for plastics it is a is a mix of 70% of 9010 and 30% of 9030. 9034 specifically labeled for plastic at low temperatures has a very low viscosity of 60cts 20°C. The concern I would have with really low viscosity oils is usually recommend surface treatment to keep the oil from spreading adding to your cost. Then 9000 has a viscosity of 100 cSt at 20°C and is specifically designed for quartz watches.
So I have used the 9000 it does work really nicely on quartz watches.
I think I will just go with 9000.
My other hobby is toy and model steam engines and if you want to start a lively discussion there you ask whether you prefer to use distilled water in your engines, or deionised water.
I think 'which oil is the best' would be the equivalent question in horology to get a wide and varied discussion.
  • 2 years later...
I'm doing my very first quartz watch movement, an ETA 955.112 (my old fathers). ETA's latest technical communication specifies 9014 for the jewel pivot holes. Now, I don't plan to service many quartz watches so I'm a bit reluctant to make the "investment". Just how bad would it be to use for example 9010 instead? I certainly wouldn't want to ruin anything, physically or the time keeping. I also have HP-1300 and thicker oils/lubricants.
M9010 is 150cst @20c. nearest other than M9000 and M9104, is M941 (for pallet stones) at 105 cst @ 20c but this is an ester not a mineral/PAO (synthetic mineral oil), so not sure of effects on plastic parts.  Like you I don't use a lot so didn't want the expense of M9000 for one or 2 watches.  I have used M9010 without trouble on an ETA 955.
Good to know and thanks for your reply! I think (but except for the experience made by you I'm guessing) that a possible (only) downside would be a shortened battery life? Anyway, if anyone can refute och confirm I'd appreciate the education.
There is another simple way to look at the lubrication problem.  You're supposed to be running a series of electrical checks to verify the watch is functioning correctly. So two tests that would be affected by increased friction are the current consumption Less than or equal to 1,20 μA. Then there is the low-voltage check both of these are not going to work properly if you have too much friction or if something else is wrong.
_c_t_ct_955112_fde_491181_10.pdf
I vote for anything  that  comes out of a distillery.
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
