Basic lathe cuts on a watchmakers lathe
clockboy
I subscribe with this Guy on youtube who does some really interesting repair vids. There has been of late a few posts on watchmakers lathes and I find this vid covering how to perform basic cuts on a lathe and his theory. Lathe work requires a whole new level of skills but well worth attaining .
