Hello from new member
Winston
Hello, I just joined today. I am a 21 years old mechanical engineering student from Montreal. I am passionate about watches and I decided to get into watch repair this year. I joined because I made a rookie mistake and I need help. On a lighter subject my collection consists of a Casio Edifice pilot chronograph, an Orient Ray II, a Zeppelin lz-129, an old seiko 5 and a Casio f-91w. See you on the forum!
Welcome to the forum. Plenty of good advice on here for you. I see you have posted a question and need help. If you could provide photos it would help. Many on here are like you just starting out and with the aid of photos they like to join in as well as the more advanced members.
