Best movements for practice?
Hey guys...I am brand new to watches and was just looking on ebay for a few movements to practice taking apart and putting together. Can you all take a look at these and let me know if they would be worth getting for this purpose?
http://www.ebay.com/itm/311339037472?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Thanks!
Matthew Condon
Yes, I thought they looked nice too. I am going to try to get them. Even though I plan to practice on them, I'll take it slow and try not to do anything that will cause damage. If they turn out to be nice movements, I might want to restore them one day.
Here's the data for the big runner:
  • Grade: 291 question.png
  • Model: 7 question.png
  • Class: 110 question.png
  • Estimated Production Year: 1919 question.png
  • Run Quantity: 4,000 question.png
  • Total Production: 1,490,000 question.png
  • Size: 16s question.png
  • Jewels: 7j question.png
  • Movement Configuration: Openface question.png
  • Movement Finish: Nickel question.png
  • Movement Setting: Pendant question.png
  • Plate: 3/4 Plate question.png
  • Barrel: Going question.png
  • Train: Quick question.png
  • Regulator: Plain question.png
  • Adjusted: No question.png
  • Railroad Grade: No
Well, I didn't get them. :( They went for $32 total. I was just a little under the winning bid. It was a few dollars over my budget at the moment anyway and I don't have any tools yet to work on them. I'm sure there will be others another day. They did look nice though. I have been looking for a new wrist watch for about 2 years now. I'm thinking I might try to find some movements to play around with and if they turn out to be nice and work well, I might convert them into wrist watches. I do love pocket watches but hate things in my pockets...I love the idea of converting these old movements into something that I personally can use.
Sorry to hear you got pipped at the auction post.
There used to be lots of old Waltham and Elgin movements on eBay and, as Bob says, ETA 6497/8 and some Hamilton movements are solid to work on. If you work on American pocket watch movements - being in the US - then replacement parts may be easier to get hold of should you need them.
For practise, try to get a watch advertised as running. Do an ebay seach for handwinds under USD25 (with free shipping!), there are a lot of garish watches from India which although hard on the eyes, represent good value for a beginner watchbreaker maker.
If you can take it apart and get it back together and running then thats a big motivational boost for you!
If you start with a watch which is not running you may be stuck and lose heart thru no fault of yours.
For a simple handwind you'd need
A simple caseback opener
A loupe (10 x )
A pair of decent tweezers (*)
Some decent screwdrivers (*)
A bottle of Zippo fluid (or equivalent) for cleaning watch parts.
Some Rodico (funky green plasticine which watchmakers use)
Some watch oil (*)
mainspring winder
parts organisor
Misc tubs and containers.
For Items marked with (*) try to buy quality stuff as poor tools will make your work so much more difficult.
Anil
Re thewatchcollector....
..... has a lot of watches and cheap too but most of them have issues and you need to have a bit of experience before you tackle these.
Notice how thewatchcollector sells his watches in 'lots' of similar models.. the idea is that you take the best from 4 watches and maybe end up with two working ones. Good deal as they're cheap enough but a bit challenging for the beginner. If you end up with two working watches out of 4 then that's good but bear in mind these will have old mainsprings and if automatic, the autowinder is usually shot. Water resistance is non-existant of course.
if you're thinking of buying from thewatchcollector then stick to seikos... well made cases and movements usually mean the watch can be saved. A lot of Seikos have hardlex crystals and these are quite difficult to polish. A replacement will probably cost more than the watch.
Anil
Good advise Anil! I recommend the watch collector as a good source and dependable seller. All you said is absolutely true, not for beginners unless you get lucky. His shipping to US takes supper long, almost a month and sometimes even more! BTW, @Matt, considering the cost of retrofitting his watches and depending on the project, the overall price may be too much so chose carefully if you do.
I may add that here, on this side of the pond, although not original/hardlex, you can substitute Seiko crystals dirt cheap. Just a 2mm thick X 28mm diameter of mineral glass, beveled, is US$2.50 and less depending on the supplier. I do it all the time and they look perfect! In my mind, using sapphire crystal would be better, even than hardlex, but it is too expensive (US$18 for 1.5 mm thick) and I haven't found a source for 2 mm thick...but I haven't looked much either.
Cheers,
Bob
I've bought a couple of movements and several parts from eBay seller vacheron_nl. He has some interesting stuff, some of it NOS. A lot of them running. The downside is that shipping takes a bit. But you can get a deal if you're patient.
A couple of things I forgot to mention....a lot of the movements they sell that don't have a dial are also missing the hour wheel, so be aware of that. Also, many of them are smaller movements. You can check the diameter of the movement in the Ranftt Database.
Edited by Don
Well after all your welcome input, I have decided to go the pocket Watch route to practice on.
And have obtained this, see picture below.
Ingersol, pocket Watch with what I understand are in some circles known as Dollar Watches.
Now I have talked to my Watchmaker about these and he owns six of them including two Automaton versions, one of which he built from a pile of bits.
He said they were simple and easy to service, but looking on various forums that opinion varies somewhat.
Now my guy can pretty much fix anything from simple no complication movements to complex chronographs plus electric and tuning fork Watches.
So from his point they probably are easy to service and repair.
But is it a good one for me to start with, if so any advice on how to take it apart.
Currently it is working and keeping good time, I would hate to ruin it, even though it didn't cost much.
Thanks for looking.
Jon
This is not the best type to start of with. It is fundementaly a two plate construction that will make reassembly very difficult indeed when it comes to aligning the drive train pinions.
A far better choice would be to go for a movement that consists of separate bridges and balance c o c k. This type is a lot easier to work on because you do not have so many pinions to align at the same time. Also it is easier to asses the free running of the components as you go.
Can't say I've ever worked on a piece like this, but I'm inclined to agree with geo,
on my early mechanical practices, I've had standard wristwatch movements (with specific bridges and cocks) that i wish i was exaggerating when I said I've sat trying to gently align pinions of the gear train for well over half an hour and very much wanting to cry. I imagine this would have made me tear my hair out.
That being said, don't regret the acquisition, put it aside, it will make a fantastically interesting and useful practice later.
Edited by Ishima
I agree with the above comments. A 3/4 plate is what I started on years ago and it proved well suited.
BTW, that is an extremely clean watch for a dollar watch. So many are abused because of their low worth (at purchase), not so much now. Great find.
I have had these and I think it's a great thing to learn on. The pivots are heavy and won't break off easy, this can be good in the early learning stages but as mentioned it's takes time but great accomplishment when it's back and ticking away.
Thanks for that, any tips if I decided to strip it?
Just make sure you let the power down
off the spring. If you take parts out with
it wound up it can strip the gears
and mess up the watch.
Try to get the best fit with the screwdriver so not to strip the screws.
I started on these types of watches, Smiths, Ingersoll, westloc and a few cheaper Canadian watches, the reason was exactly what Geo stated lining up the drive train pinions as I snapped a pivot pinion on an early waltham watch, so I practiced and practiced on these cheaper watches until I mastered aligning the pinions and it worked for me. Tought me patience and I eventually mastered aligning the pinions much easier without damaging any.
  • 9 months later...
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
