Seiko Identification
Can anyone identify this watch? My partner got it for me in September as I normally repair pocket watches but this was something different for me. It was cheap, in pieces and in a bad way but I've got it working now albeit without the case back on. The problem I have is that the caseback fouls the counterweight when it's screwed on and right at soon as the thread catches and it stops it swinging. The caseback itself has 7009-3171 printed on it and the movement is a 7009A but from Googling it would seem the watch is a 7009-3160 and my thought is that maybe this model has a slightly deeper caseback. Can anyone help?
That is a Frankenstein Seiko, from India or the Philippines. Just look at the weird numbering printed, Seiko never did anything like that and certainly not so misaligned. To get it running you got to be creative, and not too demanding.
Edited by jdm
10 minutes ago, jdm said:
That is a Frankenstein Seiko, from India or the Philippines. Just look at the weird numbering printed, Seiko never did anything like that and certainly not so misaligned. To get it running you got to be creative, and too demanding.
That is so wrong. They actually did. Somewhere i have a very similar case. But  i think it is a 6309 movement inside. But could be wrong. But have seen this before. So totally fake it's not. Could be kosher .
https://www.ebay.com/itm/NEW-SEIKO-MINERAL-CRYSTAL-30-5mm-FOR-SEIKO-7009-3160-MILITARY-MENS-WATCH-/352034930729
This is a link to a crystal for this model. So think it's kosher.
Edited by rogart63
A 6309 in a Seiko 5? Are you sure?
However I was referring to the 24h numbering, which is just uncanny in absence of 12h numbering on the inner dial. Example:
The case shape is not strange in itself, it's one of the most used, still made today.
6 minutes ago, mistergrumpy said:
I did wonder why the numbers were a bit skewed but Google results like this got me wondering.
Thanks for the link, so Rog was right. It's also missing from the popular database.
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
    • Welcome from a fellow Seiko enthusiast, there are lots of us on this forum.
    • Nickelsilver is right, movement diameter and keyless works ‘fingerprint’ are important for identifying movements. That said, this appears to be a 7 jewel version of the a Revue 30 movement.  A quick search with google turns up parts movements, and individual parts should be quite easy to come by.  Hope that helps, Mark
