What have I bought now!
Pip
I'm not even sure myself, but I saw a listing which said it's probably an old watch timing machine, but when I looked at the pics and the French labels I thought it looked more like a watch cleaning machine. It could be of course some cobbled together Heath Robinson affair. It could be of course a complete waste of money and not likely to ever work doing whatever it was built to do again. I'll know more when it arrives! But, I thought to myself, who better to ask than the hive mind here who have had every type of contraption imaginable in their workshops at one time or another. So your starter for 10 (and lots of conferring!)...
That was my thinking Mark, but I'm often wrong! The real trouble, and maybe the members can offer some advice here, is how the hell am I going to get this one in the house without the wife noticing? I think I may end up in that big box, under my patio.
watch cleaning machine: ultrasound on/off button, wringer (dryer) on/timer/off buttons, big bottom dial is the timer.
Almost looks homemade. The attachments would be the agitators/motors to stir the solution. Do you have a better picture of the note inside the lid?
Here we are...
Here we are...
Confirms it's a cleaning machine:
Average times for small watches/clocks:
12 minutes to wash
10 minutes to rinse
5 minutes to dry
Awesome. Just have to work out if it’s alive, of if not how to revive it, and then how to use it. I’m hoping there will be a manufacturer mark somewhere and I can find a manual. Someone on another forum mentioned vibrograf but I can’t find any pics that look anything like this thing.
My word, it’s alive! Had to nip out and buy a travel plug (at work and couldn’t wait) but she powers up. There are three separate glass baths, and a spinning section which I guess is for drying, goes like the clappers when you press the right button. There are 3 what look like ultrasonic transducers with leads. Have to work out how/where to plug them in and need to pull it apart a little to follow the wiring and see if there is a makers mark on it anywhere. It’s a thing of beauty which I hope I can make useful again.
I found a makers mark, it was made (or possibly distributed?) by a French company called Sepmis S.A. If anyone has any info on them or on the beast in the thread above, even if you've just seen a similar one, I'd love to hear from you!
Phil
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
