Mainspring Tool Identification
rodabod
On 20/10/2017 at 9:15 PM, Marc said:
Well spotted! I guess it is an automatic bridle winder then. Should be pretty handy as I already have a set of normal mainspring winding arbors/handles, but this Eterna set has odd sizes included which my Bergeon set doesn't already have.
Thanks.
