Pauljohno Intro
Pauljohno
Hi I am Paul Johnson
Very interested in clocks/watches my collection is as follows a 1960s manual Roamer Poplar, a Tissot Automatic 111 a Bering quartz the father in laws manual Rotary (at present wont wind and the winder has become detached)
My clocks are a 1950s Elliott mantel clock quarter chiming/ a Comitti carriage clock approx 1960s /a Matthew Norman carriage clock was my father in laws.
I love everything about timepieces and look forward to more informative clips and information,I rate your you tube site very highly.
Paul Johnson
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
