Rado Diastar 152.0332.3 3rd link needed
Ymovich
Best off finding a reputable watch repairer with the ability to order Rado parts, someone may be able to help you source a link from somewhere (though one of the graduated links is especially difficult) But then you need someone competent to fit it, it's almost common for these watches to be damaged during maintenance/repair work. It may have to be sent back to Rado, since it's not one of the standard links.
Edited by Ishima
I talked to the Rado parts services in NY, NJ region and learned that this line of parts was discontinued...  the new bracelet is very expensive.  I hope that somebody will have a knowledge of whereabouts of one used 3rd link...  or a used inexpensive bracelet with a third link present in a decent shape.
thank you for you kind reply.
Try on WatchUSeek, there is a section for trading bracelets and parts. Much less likely that you can find it here.
  • Similar Content
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
