Refurbishing a Romanian clock
utzelu
Hi,
I recently got a small vintage clock from my father in law. It is an Aradora clock, fabricated in Romania in 1978. I guess the movement was made "in house" :) as there is no marking on it.
I wanted to refurbish it a little, so I disassembled and cleaned it. So far so good, but the issue I currently have is that I cannot figure it out how to lock the mainspring on its wheel when reassembling the movement. I am able to wind the mainspring all the way, with the help of a custom fabricated jig. The problem is that space available in the movement is so restricted, that no spring containment ring fits inside. I wonder if anyone has any idea about how the mainspring could be fitted back.
Thanks,
DanP
151961049_1_1000x700_ceas-mecanic-aradora-8-rubine-1978-cu-clopotei-vintage-functional-timisoara.jpg
I think a strip of thin metal (just like a mainspring) would work, with the ends bent to link to each other in a loop. Being flexible would go around the hook and adapt to the shape.
Edited by jdm
The easy way is to just unwind the spring, the end goes over the post, hook the other end over the arbor and with the winding key start to wind it up making sure the end over the arbor is being wound on. Before you start to wind make sure you have all the wheels in place and both plates tightened up.
Somehow I think the ring should be open ended, since the mainspring has a loop end that hooked to the post on the winder. Not sure how the thin metal strip linked on the ends (basically a closed ring) would be placed on the mainspring.
BINGO! That's how it is done :) It takes quite a bit of fiddling to get the mainspring inside but it is working.
Thanks a lot!
DanP
I managed to put the movement back together and it is running. That was a good feeling, hearing the tick-tack rhythm. For the time being it runs without hands and I haven't mounted it inside the case. The thing is, the watch stops running after about 14 hours, though I would expect it to run for about 24 to 30 hours. Winding the mainspring back to max. actually needs maybe 2 full key turns. So it looks to me that there should be some more spring left after 14 hours.
Anything I should check in particular?
The mainspring is 3.5 mm x 0.35 mm, though I haven't measured the length.
Thank you,
DanP
Thank you,
DanP
This has all the signs the m/spring is the wrong one. It should last for 30 hours; it should take a lot more than two winds, it is the wrong length.
I was thinking about it too, but some doubts do come up in my mind: the clock belongs to my father-in-law and he says it was never serviced nor opened. It wasn't used for maybe 15 years but he remembers he was winding it every day when it was running. That tells me the power reserve was over 24 hours at some point in its past. Moreover, I noticed, that when I wind it up, the balance wheel doesn't turn by itself - I need to push start it for the clock to start running.
Could it be that the m/spring has degraded by not running for so long, or due to my handling when working on it?
Thanks,
DanP
First of all about the clock starting, the impulse pin should be in the centre of the pallets when it isn’t moving, this will make sure it has an even tick. To get a good action the balance tips should look like a sharpened pencil, the oil cups should be clean with no indentation; wear in these will cause poor action. If you have a lathe, you can sharpen the staff.
 I have only come across m/springs being worn or losing their strength when being used, never heard or come across one when it is idle.  I suppose if it is made of poor metal that could cause the problem. The handling of the spring hasn’t caused this.
  • 1 year later...
Hi again,
I am resurrecting this thread after a long idle time. After struggling to keep the watch running, I abandoned the project and moved on. But now I am thinking to restart working on it. So far I am kind of sure the hairspring is damaged, as I managed to warp it. I won't attend to repair it but instead I am thinking to purchase another hairspring. The clock movement being old and obscure, I have no idea about the hairspring specification. I see Cousins UK sells a set of hairsprings assortment and was thinking if it would be suitable to go on this route. I have big holes in my watchmaking knowledge and I am not sure if there is a correlation between the hairspring and the rest of the train gear and how to choose a new hairspring. So I am very eager to get educated on this matter.
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
    • I would like to see the movement. The watch is the movement. Anyone can print a name on a dial and sell it as "the maker".
    • Thanks for your answers! There seems to be a contradiction between these two answers, so perhaps I need to clarify. The flat and convex jewels look identical on the side facing away from the pivot shoulder. That is, there is an oil reservoir. I don't know if that changes anything but I thought it was safest to clarify since I didn't include a picture of the jewels from the opposite side.
    • unfortunately paying attention to details bumps up the cost. Which is why they shortchange on manufacturing steps if they can.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  When it comes to tools buy the best you can afford a good set of watch makers screwdrivers if you look after them will last you a life time. I recommend Dumont tweezers Number 3 and number 5 for fine work, you can build up from there. You will need different strength eye glasses. Some now like to work using a microscope. Pliers the box jointed ones are best they don't go out of line.
