Tightening a "THINGAMAJIG"
Hi,
I'm tinkering with a movement from a Greville watch and the clutch/cannon pinion equivalent is very loose and hence the hands don't move, although the watch works OK. It's the type with a gear fixed to the mainspring barrel, not sure what it is called, but does anybody know if it's possible to tighten them up.
Think your movement is a EB1197 ?  And don't think the problem is in the mainspring or the barrel. It's the cannon pinion that is loose and needs to be tighten up.
Or find a better one that works better.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&EB_1197
Cannon pinion on this looks something like this. 59d53d044905d_cannonpinion.jpg.41e957f122f3dce8a60b145b0b4e51ac.jpg
 I seem to remember servicing a watch movement with that style of barrel/wheel set up. If my memory is correct this set up requires a certain amount friction to drive the wheel. The mistake I made was to clean & then lubricate which reduced the friction required. I had to give it a light tap with a closing punch to give it back the friction required.
5 minutes ago, szbalogh said:
No no, the OP has right. The clutch here is on the barrel. Its a Roskopf-type solution.
And Clockboy is also right, one can tighten it with a light tap to increase friction.
I must say it's just a poxy design.
Success, the light tap treatment has worked, infact I'm a bit worried it may be too tight. We'll see. I think just a bit of hard hand pressure, with the right stake, would have done the trick. Thanks everybody for your help and replies. Richard.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
