ETA 2836-2 Auto Mechanism Issue
Dico
Hello All,
I just serviced an ETA 2836-2 which runs flawlessly up until the auto mechanism is put back on. Without the auto mechanism it runs almost a full 36 hours when fully wound but once the auto mechanism is on it stops intermittently every few hours even when its sitting still. The mechanism is seated correctly and I verified nothing is interfering with the balance. Any thoughts on what can be causing this?
Yup, this is a classic eta issue.. firstly, the rotor and reversing wheels must be as clean as physically possible..
the rotor bearing requires a very small drop of oil on 1 or 2 of the balls
each reversing wheel requires the smallest possible oil on the tip of each pawl where it contacts the mating locking surface inside the wheel, and possibly a miniscule drop between the wheel arbor and the free running wheel of the reverser (hard to describe, and sometimes this doesnt work)
I use 9010 to lubricate these, after epilaming, to make sure the oil doesn't sod off to places I don't want it ;-)
if after doing this, demagnetising, and it still makes the rotor "propellor", clean them, repeat the process and don't be surprised if you need to do it a 3rd time ;-)
if you do make it to the 3rd time, the reversing wheel may need replacing..
Tom
The Lubeta is meant to work well, unfortunately getting a single bottle of it into Australia is prohibitively expensive ($4-500) due to hazardous material charges.. the 9010 is what is used at the swatch group service centre here, and more easily available.
The lubeta does also leave a white non-uniform residue over the entire part, so isn't appropriate for watches with a visible movement.
Tom
Hi All,
So over the past 2 weeks or so I've tried cleaning and oiling the auto mechanism 3 different times...that didn't work
Change out the rotor completely to a brand new one....that didn't work
Change the whole auto mechanism including rotor to a new one....and that didn't work
I'm at a loss here....is there anything else that can be causing this god forsaken watch to stop ONLY when an auto mechanism is re-attached to it??
:startle:
Oops, I just realized you meant the main movement was stopping, I was just thinking you hadn't got the auto winding properly...
Check anywhere there might be a pivot being interfered with, (centre seconds is a common one if the second hand has been put on without supporting the jewel), that the train bridge is flat, and not being pressed on by the auto bridge, also where the auto transmission wheel post goes into the barrel bridge, there's an opportunity for pressure...
Another one that just came to mind, make sure the auto bridge isn't pressing on the regulator on the balance cock...
Tom
If the watch still runs for 36 hours without the auto then it is still the auto or auto assembly that is the issue. I have read many times that most auto wheels run better not being lubricated just cleaned. ETA developed Lubeta to address this but I would be very surprised if this was the issue. I would say it is a assembly issue. Is it possible to a post a pic or even better a short vid of the movement running and the auto rotation.
Thank you for all the great responses. Taking the advice of clockboy I’ve included 2 short videos so you all can see the movement, screws and how things are seated. In this condition shown in the video, the watch runs flawlessly.
As soon as the rotor is placed on it again it stops within 12 hours. I’ll post another video with the rotor attached. I’ve changed the whole auto assembly to a new one so I don’t think the issue is there. It must be something else. Could the mainspring barrel cause this?
7CAE1615-DF00-49CD-B7F8-B75405400A15.MOV
BD73A76B-151D-4C8C-924E-67262647F793.MOV
Hi everyone
Still having the same issue here. I noticed after the last video I posted that even after winding a few times the balance does not start moving. In fact I have to shake the watch to get it going and then it’s fine as long as rotor is off. Can that have anything to do with the stopping issue I’m encountering? Issue with the barrel?
Hi All,
I'm still troubleshooting here. Noticed when it stops its always at the 51 or 52 second mark. The hours in between are random could be as little as 10 mins or as much as 12 hours - but always stops at about the same seconds mark. What does this mean??
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
