ETA 2836-2 Auto Mechanism Issue
Dico
Hello All,
I just serviced an ETA 2836-2 which runs flawlessly up until the auto mechanism is put back on. Without the auto mechanism it runs almost a full 36 hours when fully wound but once the auto mechanism is on it stops intermittently every few hours even when its sitting still. The mechanism is seated correctly and I verified nothing is interfering with the balance. Any thoughts on what can be causing this?
Yup, this is a classic eta issue.. firstly, the rotor and reversing wheels must be as clean as physically possible..
the rotor bearing requires a very small drop of oil on 1 or 2 of the balls
each reversing wheel requires the smallest possible oil on the tip of each pawl where it contacts the mating locking surface inside the wheel, and possibly a miniscule drop between the wheel arbor and the free running wheel of the reverser (hard to describe, and sometimes this doesnt work)
I use 9010 to lubricate these, after epilaming, to make sure the oil doesn't sod off to places I don't want it ;-)
if after doing this, demagnetising, and it still makes the rotor "propellor", clean them, repeat the process and don't be surprised if you need to do it a 3rd time ;-)
if you do make it to the 3rd time, the reversing wheel may need replacing..
Tom
The Lubeta is meant to work well, unfortunately getting a single bottle of it into Australia is prohibitively expensive ($4-500) due to hazardous material charges.. the 9010 is what is used at the swatch group service centre here, and more easily available.
The lubeta does also leave a white non-uniform residue over the entire part, so isn't appropriate for watches with a visible movement.
Tom
Hi All,
So over the past 2 weeks or so I've tried cleaning and oiling the auto mechanism 3 different times...that didn't work
Change out the rotor completely to a brand new one....that didn't work
Change the whole auto mechanism including rotor to a new one....and that didn't work
I'm at a loss here....is there anything else that can be causing this god forsaken watch to stop ONLY when an auto mechanism is re-attached to it??
:startle:
Oops, I just realized you meant the main movement was stopping, I was just thinking you hadn't got the auto winding properly...
Check anywhere there might be a pivot being interfered with, (centre seconds is a common one if the second hand has been put on without supporting the jewel), that the train bridge is flat, and not being pressed on by the auto bridge, also where the auto transmission wheel post goes into the barrel bridge, there's an opportunity for pressure...
Another one that just came to mind, make sure the auto bridge isn't pressing on the regulator on the balance cock...
Tom
If the watch still runs for 36 hours without the auto then it is still the auto or auto assembly that is the issue. I have read many times that most auto wheels run better not being lubricated just cleaned. ETA developed Lubeta to address this but I would be very surprised if this was the issue. I would say it is a assembly issue. Is it possible to a post a pic or even better a short vid of the movement running and the auto rotation.
Thank you for all the great responses. Taking the advice of clockboy I’ve included 2 short videos so you all can see the movement, screws and how things are seated. In this condition shown in the video, the watch runs flawlessly.
As soon as the rotor is placed on it again it stops within 12 hours. I’ll post another video with the rotor attached. I’ve changed the whole auto assembly to a new one so I don’t think the issue is there. It must be something else. Could the mainspring barrel cause this?
7CAE1615-DF00-49CD-B7F8-B75405400A15.MOV
BD73A76B-151D-4C8C-924E-67262647F793.MOV
Hi everyone
Still having the same issue here. I noticed after the last video I posted that even after winding a few times the balance does not start moving. In fact I have to shake the watch to get it going and then it’s fine as long as rotor is off. Can that have anything to do with the stopping issue I’m encountering? Issue with the barrel?
Hi All,
I'm still troubleshooting here. Noticed when it stops its always at the 51 or 52 second mark. The hours in between are random could be as little as 10 mins or as much as 12 hours - but always stops at about the same seconds mark. What does this mean??
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
