Best Stock for Making Balance Staff
jdrichard
If You can find some old road-racer spokes. They are super strong after treated like praezis said. Or there are some steel nails (they are blue or black compared to the regular nails), but they have low carbon, hence not that hard after tempering.
There are also some writings on the net making the staff from softened steel and harden it after turning. No tempering here so it will become hard but not so strong.
But a guy at Tag Heuer said he is making staffs from wheelman's nails :D But i found that it is way to soft. No carbon content at all. It is breaking and bending in the lathe.
The site old hippy linked to mentions its silver steel.  JD, silver steel or drill rod in NA is usually (often) O1, but it can also be W1 (you need to know the difference else you don't know how to heat treat it), that has been hardened them tempered to blue.   Its bought annealed.  Hardening is via quench and, well,  hardens it,  tempering lets it down by heat so its not so brittle (and a little less hard).   When making tools its nice to work with it annealed (as you buy it) then harden and temper so that would be where I'm most comfortable.  It carries the added work of heat treating and tempering but is easier to machine.  Just my view, I can see how others would prefer to skip that step but then there's the added complexity of sharpen carbide gravers (something I find a bit of a pita)
Quote
You can only heat treat and make hard a piece of steel if it has the right chemistry which usually means > .5 % carbon, for example carbon tool steel (O1, W1, A2 etc).  mild steel doesn't have enough carbon to heat treat (for the sticklers you can get some increase in hardness from a cold brine quench, but it is almost negligible) except by case hardening which is a bit different process, carbon is infused in the outer layer via a soak at heat.  Not applicable (imo) to a part like this
Edited by measuretwice
The stock I had when I took over the workshop was blue steel and I never needed to soften it. I learned from my master how to make balance staffs from the stock we had. He didn’t teach me about what you have mentioned because I suppose there was no need, there was loads of the stuff.  I do remember him saying about what type of graver to use and how you go about sharpening such a tool.
I also had a box of unfinished partly turned staffs, which was also very handy. They ranged from watch size to pocket watch. Never needed to treat them in any way.
That ol blue steel stock I had it must have been made back in 1900 or around that time as it came from my masters father who also was a watchmaker. I'm wondering if back then steel was made and treated different from modern day.
I have no way of knowing for sure, but would think it a probability its carbon tool steel that's been heat treated and tempered, O1 ,W1 or A2 (almost not material like difference between, except cost and how they are quenched).   Personal preference is to work with it in the annealed state - I didn't mean to suggest anyone would or should anneal the blue steel, but when you buy say O1 it comes annealed.
4 hours ago, szbalogh said:
To increase confusion, this guy made it from HSS drill bit :)
http://joyofprecision.com/post/11958667783/turning-a-balance-staff-part-1
This is a rational choice because hss tend to have the best balance of hardness and toughness.
Max's site.  He goes by the name mars-red and is quite competent, I know him from machining sites.  I don't think he says a hss drill so perhaps it was carbon - again likely O1 or W1.  imo its an strange choice, a drill, but it might have been just what he had and it worked.  If it was HSS, he could have gone through the steps, but I'll push back that he hardened it.   HSS is extremely tricky to heat treat, can't be done without a controlled oven.
The reason is the temperature control has to be very precise - it has a small sweet spot.  Its generally not considered possible without specialized equipment.   Just for interest, carbon steel is as hard and tough as hss, but where hss shines is it holds its hardness at higher temps.  This is why you can make all manner of cutting tools from tool steel and they work and last just fine so long as you run them slowly.  HSS has obvious advantages for machine cutting tools as things can be run faster, but its also advantages in that the grinding won't affect the temper.  i.e. your plane blade won't ever be used fast enough to get any benefit from HSS, but you can grind (where the point of contact temps are high) the bevel on the HSS without affecting the temper.
What I need in the source (provided as a web link) for the steel i should purchase to cut a balance staff. O1, W1: dont care, just want material that i can cut without any preparation. If i need to temper it after, I'll have to figure that out. Please help a Friendly Canadian :)
Interesting
You can start with a simple nail, to practice. Moreover, the finished part can be hardened if heated in carbon powder. This will add carbon to the outer layer. The longer you treat it the thicker the high-carbon layer will be. And polish thereafter.
I think you have cleared up my misleading remarks at the beginning. Thanks.
No nails that dont have a swirl. So where can i buy the specific stock?
Take your pick.....
https://www.cousinsuk.com/category/pivot-steel
https://www.hswalsh.com/product/blue-pivot-steel-wire
http://www.m-p.co.uk/muk/parts/chap10/pivot-steel-0.61mm.-10pcs-no.72-0618007215.htm
https://www.esslinger.com/staff-and-pivot-watch-and-clock-wire-rod-assortment-blue-steel-55-1-93mm-12-pieces/
http://timesavers.com/i-24049935-30-pack-3-00mm-3-95mm-blue-wire-assortment.html
https://www.amazon.com/Assorted-Tempered-Pivots-repair-pinions/dp/B01N1SOLDF
http://redroosteruk.com/11-assorted-tempered-blue-steel-wire-pivots-clock-repair-pivot-pinions-staffs/
https://perrinwatchparts.com/collections/metals/products/pivot_wire_43_2115?variant=37875445135
Google "blue pivot steel" and you will find more.
This has been the basic stock for watch and clock pivots and staffs forever. It is a carbon steel that has been hardened and then tempered back to a dark blue so that it can be cut on a lathe. It is still quite hard, try and cut it with snips and it will resist, eventually giving suddenly and breaking rather than cutting. In the lathe though it cuts easily with either a tungsten carbide or HSS graver, although a HSS graver will need frequent touching up to keep it cutting with a good clean finish. Keep a hard Arkansas slip by the lathe for this. Let it get too dull and it will chatter, resulting in a poorer finish, and it will also cause you to apply more pressure to get it to cut. If you're not careful you will break off the work piece by pushing too hard. Don't try to cut it too quickly either, and don't expect long curls of swarf. Take your time and make dust. You will get a better finish and the HSS graver will keep its edge longer, whilst the tungsten carbide will be less likely to chip.It also burnishes well so don't try to cut the pivots to size in the lathe, leave them over size and finish in the Jacot tool.
This doesn't need any further heat treating when you're done, it already has the right balance of hardness and strength for pivots and staffs, especially if you burnish the pivots in the Jacot as this locally work hardens the surface giving the correct hardness to resist wear whilst the rest of the staff retains enough strength to cope with a degree of mechanical shock without shattering.
Practise and enjoy.
Take your pick.....
Practise and enjoy.
Mark, you and OH have been great help all along. I will move forward and get the material. Below is a practice cut. I know i have years before i can cut a good balance staff7fb73f8eaa0ac516deb4eda1295ef9a1.jpg and my setupcc6c4e947712fada6d86d69fa736611d.jpg
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
