Lew & Me
R.I.P Rusty.  Died of a sudden heart attack in his sleep 2 days ago.  Only 7 years old.  Soft, gentle and unassuming.  He liked to lick fingers and would only eat the jelly around the cat food.  What an amazing little boy who will be missed dearly.
  • Sad 2
  • 6 months later...
Hello all.  It’s been a while since I logged in here to chat.  I discovered Facebook and found Mark’s Facebook forum which is keeping me occupied. I do feel compelled to return however to check out one of my all time favourite threads, “Lew & Me”.  Well since last logging in, I have gained another stray. My wife and I discovered this little tabby fellow soaking wet, shivering and near his end whilst we were out walking in the woods one day.  Happy to say he has now been adopted by us and in fine fetter.  His name is ‘Monty’, and settled in perfectly.  Thankfully he is not as interested in watches as is his ginger step-brother Joey
  • Similar Content
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
