Lathe Belts and Oiling
jdrichard
You can get the belting off ebay you cut it to length and splice it together by heating the ends  Mark has made a video on the subject :
3 in 1 oil is what I use for oiling the bearings on my lathe. The belt should  have  enough tension that it does not slip but not very tight as this will risk damaging the bearings
Is your lathe cone bearing type? And is it 3 in 1 like this?21ef233e779f8a50dabe3a7dbc17bfab.jpg
Where would i find belts for my new old boley lathe. And how tight should the lathe belt be? And what type of oil do i use to oil the lathe headstock and the lathe motor.
Thanks ahead of time.
Boley are still trading. Type in Boley watch parts and you should find their German web page. You could try contacting them if you can't find the specific belt.
Most belts for most types of machinery are set at a maximum of half inch deflection, if that's any help
Years ago I switched from the "welded" belts to seemless O-Rings. They are stronger, grip better, last longer, are inexpensive, and most importantly for me, they don't make a clacking sound every time the seam in the belt hits a pulley. I purchased mine from MSC but any industrial supplier should be able to provide them. As luck would have it, the cheapest belt material worked out to be the best for the lathe application.
david
For the lathe cone bearigs I prefer something a little thicker than 3 & 1 oil. I use hydraulic oil but a thin motor oil will also work. I purchase my hydraulic oil in a  5 gallon metal bucket from a hardware store. This is because I also use it as a solvent in a small solvent sink. For cone bearing applications a small should last several lifetimes. Small quantities can be purchased from an auto parts store.
david
david
Thanks David. Do you have an on-line source for your belts.
david
What is the specific criteria of the search for the MSC belt, or the product name and code
You may find this interesting
http://www.opensourcemachinetools.org/archive-manuals/watch_makers_lathe.pdf
Spindle oils (also known as high speed spindle oil) is usually thin (ie low viscosity) between ISO VG4 and ISO VG15.  Typically paraffin/kerosine is about ISO VG2 to 3.
This source may help
http://www.small-lathes.co.uk/Lathe-Oil-–-ISO-15-–-500-ml-Bottle-[Stk.-No.-WLO15500]/422.htm
Most other parts are medium viscosity VG68 to VG100 which are similar viscosity to say Moebius 9020 or a thin engine oil SAE 10 to 20.
The VG number indicates the mean viscosity in cSt at 40degC, (ie can actually be say 64-72 cSt for VG68)
  VG68 to 100  could also be used for the motor bearings which may require an oil gun (similar to  small grease gun but oil is used), being careful to inject a couple of drops only to avoid contaminating the electrical parts inside the motor.  Normally this when motor has plain bearings, later motors are normally grease lubricated.
david
david
Again, thanks. I think i am going to go with Mobile 1 Synth 0W20
JDRichard,
The diameter I like the best is 3/16 of an inch.  If you go the the MSC section on O-Rings you will find pages of different rings cataloged according to diameter and length. The rings are given a number called a dash number but there will be  an explanation on how to convert the size you are looking for to that number.
david
    • So I just wanted to say "thank you" again.  The angle is the key bit it seems and yes, it did basically just fall, or float, back into position when I got it lined up just right.
    • Well I’ve never seen the make before and cannot find any info, I haven’t got it just yet it’s been left to me among a 1970’s sea master and a mid size yeoman. But if anyone has any information on this one please feel free to enlighten me, many thanks
    • Hello Horologists, thought I'd introduce myself. I'm a 50ish year old who has been dabbling in watches for a while, did a couple of BHI course here in the UK and have started to dabble at bit more. I also took the level 1 course, which was a good refresher. Now off to look at some Bergeon tools and then buy (and regret buying) the cheaper ones...    Stirky.
    • Hi All, I thought I'd draw a diagram to help me understand the motion works for an eta 6497 so I thought I'd share it here in case anyone else finds it helpful. Any corrections, please let me know! Hope it helps. Stirky.
