pallet staff exchange
matabog
Hello!
I have a question, if I may: is there any way I could exchange the staff on the left with the one on the right? I would need to push out both of them and push back the good one on the left pallet fork.
The staff is 0.4 mm and the pivot is 0.12 mm.
Is there a stake (4.7mm ones) that small? I need to change it because the end fork is damaged (don't know if you distinguish in the second photo).
Thank you,
Bogdan
:) Thank you for the advices!
@FlyingWatchmaker  At the moment I don't have a jeweling tool, just a staking tool. The straightness is pretty ok - I will try to make a diy punch from a G28 or G29 needle - I'll put it in a 0.35 punch and push out the axle. To put back the axle in the other pallet, the 0.3 punch should work.
We will see :)
@StuartBaker104   I have that book :)
it's just for fun :)
the watch is ok, I had a good spare pallet. now I am playing with two scrapes. One has a broken pivot and the other has the fork affected (the impulse jewel end) - I got nothing to lose :)
the movement is Landeron 48 but I don't think it matters - a pallet is a pallet is a pallet :)
