Rotating Bezel remover.
digginstony
50 minutes ago, clockboy said:
The best way I have found to remove a bezel is with a old butter knife. It has a nice thin blade but is flexible so no damage to the bezel or case. Trusty butter knife/bezel remover
Try that on a Seiko Sumo, or even a 007 and you'll have it bent or in two parts. A flexible blade may not damage the case but it's also ineffective. Hard bezels are removed with a Seiko S-28x knife opener, (or a good copy), and the tip may need further sharpening. The large handle allows to pry correctly, remember that damage is done when twisting, but when you pull the tool handle up, the tip pushes on the case which is covered by the bezel, and the lower edge of the bezel, leaving no marks.
24 minutes ago, clockboy said:
I have used my butter knife method with Seiko divers, and also used it with my Rolex and Citizen bezels with no problems. Perhaps the Sumo is a different stye of bezel.
It's the same style, but much harder and inaccessible on the sides. If you could have a video removing an SKX007 bezel with a butter knife and no twisting, I'd love to see it.
Next time I get a diver or watch with a  bezel I will do. Watch this space !!!!
Please try on a Seiko 007/9, which is the specific watch I was referring to. I agree that other types may be much easier to remove with improvised tools.
Ok I had a spare hour this afternoon so I thought I would have a go removing my Urchin bezel using a knife.
After about 20 minutes using a whole selection of kitchen knives and being totally red faced I hadn't made any progress (The Mrs won't be happy with me when she gets home from work and sees the knives either) I even taped the lugs and tried leverage and twisting, still no joy, so I gave up.
So I got the Horotec case grab out and removed the bezel in a couple of minutes. I don't reckon this tool to much as a case back remover but as a bezel remover, it's the BEST I've come across.
So insert the jaws apply tension, the bezel pops and gently lift up with no effort with a Seiko type case back remover. See pics e606e40bfd5a240ef5adaa134fe4ee8f.jpgea103fb03c65903b9d118e44c5065d79.jpg03b29f2631fc9b0e12ab4c11aa0df30d.jpg
That's heavy machinery! I have a Sumo which will need the bezel removed, and I would be much more relaxed with it. Will look on AliX for a knock-off :biggrin:
That's heavy machinery! I have a Sumo which will need the bezel removed, and I would be much more relaxed with it. Will look on AliX for a knock-off [emoji3]
From what you've said, this sort of tool could be ideal for a Sumo. I haven't been tinkering with wrist watches for that long, normally I play about with pocket watches but over the last year or so have certainly fallen for Seikos. This tool has been perfect for my skx,turtle and urchin.
As for using a knife, if there is a knack to it I certainly haven't got it. [emoji30]
Sent from my SM-T585 using Tapatalk
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it.
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
