ETA 902.002 Quartz stem removal ??
Blubarb
I would like to remove the stem of this ETA 902.002 movement. I am pressing where I think I should be to release the crown stem (see pic) but there is no movement.
Help appreciated?
Edited by Blubarb
Got it sorted!  For future reference:
It will only release in one crown position (you have to see where it lines up) and requires something long and thin, in this case a small safety pin, as the release is deep in the movement.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
