Howard Miller Triple Chime
ricardopalamino
Aloha All ,
I'm not really a collector of clocks or pocket watches , although I have a few of each I picked up in my searches down different avenues .
I managed to pick up this Howard Miller Triple Chime Mantle clock at the swap meet for $65 with intentions to resell it on craigslist or ebay . I think the model is called ,"Bellingham" .
This particular clock has triple chimes that can be selected with a lever behind the dial glass and it can also be silenced with the same lever .  It has 8 hammers and what ever you call the things that the hammer strikes . What struck me is the beautiful tone of the chimes . The chimes that can be selected are called Whitt. , St. Michael's , and Westminster ,...I think . Please correct if I'm in error on these chime names .  Anyway , I am partial to the St . Michaels chime ,...very nice , melodic , and mellow .
And some Pics to share...
Thanks ,
Louis
Edited by ricardopalamino
Thats a nice clock.It looks like it has a newish case & dial. I would also say it is what is called a Napoleon hat style case and the movement has a floating balance which has the advantage of not needing to be exactly level for it to work efficiently.
Thanks for all the great Info fellows .
Clockboy ,  I may be mistaken , but I don't think the clock is that old . In my little bit of research I think I found an approx . date of manufacture and I seem to remember I was surprised that it was older then I thought it might be .
Oldhippy , you are , as always , a plethora of information .  I'm glad you chimed in .....Yuk Yuk..
Howzit vinn3 , ....what's a "tamborie" ?
The movement is a Franz Hermle 1050-020 rebadged for Howard Miller it is as already stated very modern. Franz hermle movements are date coded they use to have up until 1988 a two digit number representing the year 85, 1985 86, 1986 and so on, they then changed to a date letter starting off with A, in 1988 B, 1989, C, 1990 and so on. Look just above the Howard Miller stamp and see if there is a date letter that should give you the year of manufacture.
Edited by wls1971
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
    • Thanks guys.  quick question. For automatic movement, particularly this one. can I power down the main spring by pushing this rachet down?  i've gotten pretty used to SW210 and powering down a manual movement. But so far i've only been waiting for the auto movement to run out of juice before opening the case.
