Howard Miller Triple Chime
ricardopalamino
Aloha All ,
I'm not really a collector of clocks or pocket watches , although I have a few of each I picked up in my searches down different avenues .
I managed to pick up this Howard Miller Triple Chime Mantle clock at the swap meet for $65 with intentions to resell it on craigslist or ebay . I think the model is called ,"Bellingham" .
This particular clock has triple chimes that can be selected with a lever behind the dial glass and it can also be silenced with the same lever .  It has 8 hammers and what ever you call the things that the hammer strikes . What struck me is the beautiful tone of the chimes . The chimes that can be selected are called Whitt. , St. Michael's , and Westminster ,...I think . Please correct if I'm in error on these chime names .  Anyway , I am partial to the St . Michaels chime ,...very nice , melodic , and mellow .
And some Pics to share...
Thanks ,
Louis
Edited by ricardopalamino
Thats a nice clock.It looks like it has a newish case & dial. I would also say it is what is called a Napoleon hat style case and the movement has a floating balance which has the advantage of not needing to be exactly level for it to work efficiently.
Thanks for all the great Info fellows .
Clockboy ,  I may be mistaken , but I don't think the clock is that old . In my little bit of research I think I found an approx . date of manufacture and I seem to remember I was surprised that it was older then I thought it might be .
Oldhippy , you are , as always , a plethora of information .  I'm glad you chimed in .....Yuk Yuk..
Howzit vinn3 , ....what's a "tamborie" ?
The movement is a Franz Hermle 1050-020 rebadged for Howard Miller it is as already stated very modern. Franz hermle movements are date coded they use to have up until 1988 a two digit number representing the year 85, 1985 86, 1986 and so on, they then changed to a date letter starting off with A, in 1988 B, 1989, C, 1990 and so on. Look just above the Howard Miller stamp and see if there is a date letter that should give you the year of manufacture.
Edited by wls1971
