Obtaining a new movement
Hi, can anyone help me with getting  a new movement for a watch.
A friend has asked me to try and get her watch going. She had it as a gift many years ago and it has sentimental value for her.
It's an all metal quartz movement and the watch came from Disneyland with Poo bear on the dial.
The only marking on the movement is " one jewel " and " France Ebauches "
Does anyone have any idea if I can obtain a new plastic quartz movement to replace this one and how would I identify the correct movement.
Edited by Alaskamick
Add Photos
