Hi all,
I just got my hands on a Ricoh automatic and am currently working on it. Its all dismantled and taken apart and I'll be starting to clean it and put it back together again.
Coincidentally another member here 'arkobugg' is also working on the same movement and posed a question here
about the set-lever spring.. isn't that funny? I haven't really given serious thought about this particular movement and when I bought it I was thinking that it was an uncommon movement and along comes another one!
Anyway here are some pictures from the eb@y seller.. pictures show the watch is externally rough but internal parts are quite ok and worth a gamble, besides I like the 'split-day/date' displays. When I got it I found the dial was in bad shape.. the applied RICOH logo was bent/broken as well...ah well...
The date-pusher was jammed up and I was hoping that the spring inside was ok as it seems to be a rivetted construction. After a soak and some vigorous scrubbing and a few blasts of WD-40 followed by soap and more brushing it seems to be ok now.
I'll probably have a go at putting it back together again this weekend and I'll be sharing some pictures here.
cheers
Anilv
I am working also on this movement. Recorded the whole disassebly.... but my tablet generated a 0 kb file... :pulling-hair-out:
Anyway, here is it disassembled. I have also an other one from India, it was 2.5 USD.... Bought it for replacement parts but it is fully working :) I will record that next time and the reassembly of this one.
20863480_1515789608538897_5989096506801210009_o.thumb.jpg.bc6f89202818aa5e749a77a1aaa944c1.jpg
  • 3 months later...
  • 4 years later...
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
