Remove Back of Kronotron Pocket Watch
It would be helpful to post a picture of the caseback!
Anyway on these watches I guess it a snap back.. look around the edge and you should see a gap where you can insert a tool and twist. If you're going to do it yourself with a knife take precautions as the knife will slip easily and can seriously hurt you.
'Lifetime mainspring'.. to me this usually means a pin-lever movement. not really high-end horology but works OK.
HTH
Anilv
As said. Using a bit of magnification look for a gap in the back to slot a knife in. If not it's a screw back and bezel might be as well but not always. The problem is with this type of case, as you loosen one it naturally tightens the other and they can end up both being very stiff to remove.
