Trouble with bracelet watch
Wes
Hi,
New to the forum and new watch  repair hobbyist. I have been replacing batteries in my wife's multitude of watches. Mostly inexpensive ones that if I mess up won't be devastating.
I've been mostly successful but I ran across a watch with plastic bracelets, one on each side. There is one pin attaching the bracelet to the body of the watch and a coil spring that fits inside the housing where the bracelet is attached. It came off easy enough when I removed the pin, now I can't get it to go back together.
Just wondered if there is a special tool or a trick that a beginner like me doesn't have (the tool and/or the knowledge) can use to put this thing together properly.
It's a matter of pride now, I don't want this problem to defeat me. Although it is definitely winning. Any advice is appreciated.
As long as the holes in the bracelet and the watch is okay. A watchmaker could put a new springbar on. maybe he can use the old one.
It could be a little tricky on thus as it's not a normal case or bracelet. And there are some spring to hold the bracelet down. Put a leather strap on it instead :)
You can buy a spring bar tool on eBay for a quid or so. It's like a screwdriver with a notch in it.
You need to engage one end of the spring bar in the hole in the case and use the tool to compress the hidden spring inside the spring bar and wiggle the bar end into the other hole. You'll also have to fight the spring in the bracelet.
Three hands will help.
Eventually you'll get the idea.
Having the spring bar ping across the room is part of the fun!
Cheers Neil
Thank you for the reply. I realized that I didn't state the actual problem in my OP. If you look closely at the spring there is a raised area that fits inside the housing to produce tension. I can put it together but only when the raised part of the spring is outside of the housing, when I put the raised part of the coil inside where it is supposed to be, I then can't line up the band to properly seat the pin in both holes. I can get one side in but not the other.
Thanks Neil, I do have a spring bar tool, the real issue is with the coiled spring fitting inside the case and then lining up both holes to get the pin in.
i actually can compress both sides of the pin so it is inside the case but it won't line up when the coil spring is inside where it belongs. It will line up if the coil is outside the case but then the bracelet is wide open and won't tension to the wrist as it should. It tensions outward instead.
My fault for not explaining properly. I do appreciate the help though.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes.
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
